Results 1 to 10 of 13
Thread: Remote extension not ringing
    Default Remote extension not ringing
    I placed an snom360 on the wan side of an Epygi Quadro 2 and configured one of it's lines as a remote extension (R13).
    The subnets are as follows:
    Quadro Lan -> 192.168.224.0
    Quadro Wan -> 192.168.222.0
    The other 2 lines (ip-10 and ip-14) register from the same phone as a regular extension.
    Unfortunatly even though R13 is registered and I can place PSTN and PBX calls from R13 with no problem, R13 does not receive calls. Upon ringing R13 from PSTN or PBX the voice box will always kick in immediatly.
    That is actually the problem I wanted to solve by defining that remote extension, as this is also the behavior of ip-10 and ip-14 in the same set-up.
    If the Snom360 is place on the lan side of the Quadro 2 everything works as intended.
    Does anyone have a hint how to get the R13 ringing (other than placing it on the Lan port of the Epygi - that has some other fallbacks in regards to actual placement of the quadro in the house and available cabling)?
    We would need to look on Call Controlling logs (go to Diagnostics -> Show System Logs -> System Logs Settings -> switch ON ther "Enable Developer Logging" -> Save; then make your test call (to R13), then copy and paste here the logs from Diagnostics -> Show System Logs -> View System Logs -> Call Controlling.
    15:31:06.645 AddPBXCall: line #2, callID - 5220264166803718973.
    .648 * <- * OnAdvFxsCallMake: line #2[0](e:12), dialed number - 13, callID - 5220264166803718973, media - [<D>192.168.224.52:5004, a: G722(9), PCMU(0), PCMA(8), G723(4), G729(18), telephone-event(101)].
    .649 ATS: line #2(e:12) - OffHookWaiting.
    .649 TS: line #2[0](e:12) - OffHookWaiting.
    .719 GetCR: [PBX/12|13]-><[1-4]?>->PBX/13.
    .719 TS: line #2[0](e:12) - OffHookDialComplete.
    .720 * -> * MakeRoutingPBXCall: line #2[0](e:12), calling to extension 13, number of records - 1.
    .731 GetCoinsideInterfaces: {MG20}[192.168.224.52] <-> {MG27}[192.168.222.23].
    .734 BeginMediaSession: {MG20} - [32117396073021927]<32117396073021927>.
    .748 RequestMgResource: {MG20}[L:192.168.224.52, R:192.168.224.1], line #2[0], OutMakeIntCall, media - [<D>192.168.224.52:0, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], NM:1, NP:1, ND:1, callID - 32117396073021927.
    .749 InsertEndpoint: {MG20}<RTP/1001>[192.168.224.52:5004] - 32117396073021927.
    .752 ProcessMgReply: {MG20}, line #2, OutMakeIntCall, RTP port - 5004, CAC result - OK, media - [<D>192.168.224.52:5004, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], callID - 32117396073021927.
    .755 GetCoinsideInterfaces: {MG0}[192.168.224.1] <-> {MG20}[192.168.224.52].
    .756 GetCoinsideInterfaces: {MG0}[192.168.222.100] <-> {MG27}[192.168.222.23].
    .757 BeginMediaSession: {MG0} - [32117396073021927]<32117396073021927>.
    .761 RequestMgResource: {MG0}[L:192.168.224.1, R:192.168.224.52], line #2[0], OutMakeIpRtpBridge, media - [<D>192.168.224.1:5004, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], NM:1, NP:1, ND:1, callID - 32117396073021927.
    .783 InsertEndpoint: {MG0}<RTP/1001>[192.168.224.1:6012] - 32117396073021927.
    .785 ProcessMgReply: {MG0}, line #2, OutMakeIpRtpBridge, RTP port - 6012, CAC result - OK, media - [<D>192.168.224.1:5004, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], callID - 32117396073021927.
    .789 RequestMgResource: {MG0}[L:192.168.222.100, R:192.168.222.23], line #2[0], OutMakeIpRtpBridge, media - [<D>192.168.222.100:5004, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], NM:1, NP:1, ND:1, callID - 32117396073021927.
    .820 InsertEndpoint: {MG0}<RTP/1002>[192.168.222.100:6014] - 32117396073021927.
    .822 ProcessMgReply: {MG0}, line #2, OutMakeIpRtpBridge, RTP port - 6014, CAC result - OK, media - [<D>192.168.222.100:5004, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], callID - 32117396073021927.
    .824 * <- * OnInternalCallMake: caller line #2[0](e:12), target line #3(e:13), GUID: 72b0a81e-4975-42ad-866e-b79e4748a865, callID - 32117396073021927.
    .828 AcceptMedia: line #3(e:13) - [<D>192.168.222.100:6014, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)].
    .829 GetProperInterface: {MG27} - corresponding interface for remote address 192.168.222.100 is 192.168.222.23.
    .836 BeginMediaSession: {MG27} - [32117396073021927]<32117396073021927>.
    .850 RequestMgResource: {MG27}[L:192.168.222.23, R:192.168.222.100], line #3[0], InMakeIntCall, media - [<D>192.168.222.23:6014, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], NM:1, NP:1, ND:1, callID - 32117396073021927.
    .854 InsertEndpoint: {MG27}<RTP/1001>[192.168.222.23:9077] - 32117396073021927.
    .856 ProcessMgReply: {MG27}, InMakeIntCall, extension - 13, RTP port - 9077, CAC result - OK, media - [<D>192.168.222.23:9077, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], callID - 32117396073021927.
    .859 AcceptMedia: line #3(e:13) - [<D>192.168.222.100:6014, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)].
    .861 ATS: line #3(e:13) - OffHookWaiting.
    .862 TS: line #3[0](e:13) - OnHookRinging.
    .863 AddPBXCall: line #3, callID - 32117396073162722.
    .876 RequestPBXCallNatMapping: SPMG CallMake, remote addr - 192.168.222.23, self data - [192.168.222.100:6014], callID - 32117396073162722.
    .879 ProcessPBXCallNatReply: SPMG CallMake, result - TRUE, mapped data - [0.0.0.0(192.168.222.100):0(6014)], callID - 32117396073162722.
    .881 AttachIncomingPBXCall: line #3[0](e:13), caller line #2(e:12), callID - 32117396073021927.
    .884 * -> * MakeAdvFxsPBXCall: line #3[0](e:13), caller - "Atelier" 12, callID - 32117396073021927[32117396073162722], media - [<D>192.168.222.100:6014, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)].
    .987 OnAdvFxsPBXCallReportError(InMakeCall): line #3[0](e:13), error - "Request Rejected", callID - 32117396073021927[32117396073162722].
    .992 EndNatSession: callID - 32117396073162722.
    .999 AddVirtualTrunk: {MG27}, line #64(e:13).
    .1000 ProcessAdvFxsPBXCallError: initiator line #2, target line #3[0](e:13) is busy, activating auto responder, callID - 32117396073021927.
    15:31:07.001 TS: line #64(e:13) - OnHookRinging.
    .003 ATS: line #3(e:13) - OnHookSilent.
    .003 TS: line #3[0](e:13) - OnHookSilent.
    .005 ErasePBXCall: callID - 32117396073162722.
    .006 AddPBXCall: line #64, callID - 32117396073021927.
    .007 OnInternalCallRinging: caller line #2[0](e:12), target line #64[0](e:13), callID - 32117396073021927.
    .008 TS: line #2[0](e:12) - OffHookRinging.
    .009 RingingAdvFxsPBXCall: line #2[0](e:12), callID - 32117396073021927[5220264166803718973], media - [N/A].
    .026 SetTimer: line #64, type - QuickResponse, interval - 1 sec, callID - 32117396073021927.
    15:31:08.022 ProcessTimerTask: type - QuickResponse, line #64, callID - 32117396073021927.
    .023 EndMediaSession: {MG27} - 32117396073021927.
    .024 EraseEndpoint: {MG27}<RTP/1001>[192.168.222.23:9077] - 32117396073021927.
    .025 TidyMediaStatisticRequest: MG{0}, callID - 32116245021540971, sessID - 32116245021540971, remain records - 0.
    .027 EndMediaSession: RESET {MG27}.
    .032 <<<<<<<<<<<< Handle Map >>>>>>>>>>>>
    C:
    #64, ID - 32117396073021927.->PBX
    #2 , ID - 5220264166803718973.->PBX
    S:
    {MG0} - 32117396073021927.
    {MG20} - 32117396073021927.
    .033 GetCoinsideInterfaces: {MG0}[192.168.224.1] <-> {MG20}[192.168.224.52].
    .034 ResetRtpBridge: line #2[0](e:12), callID - 32117396073021927.
    .034 EndMediaSession: {MG0} - 32117396073021927.
    .035 EraseEndpoint: {MG0}<RTP/1001>[192.168.224.1:6012] - 32117396073021927.
    .036 EraseEndpoint: {MG0}<RTP/1002>[192.168.222.100:6014] - 32117396073021927.
    .038 EndMediaSession: {MG0} - 32117396073021927, ownerID - 32117396073021927, requesting RTP statistics.
    .039 EndMediaSession: RESET {MG0}.
    .042 <<<<<<<<<<<< Handle Map >>>>>>>>>>>>
    C:
    S:
    .045 BeginMediaSession: {MG0} - [32117396073021927]<32117396073021927>.
    .048 RequestMgResource: {MG0}[L:192.168.224.1, R:192.168.224.52], line #64[0], AcceptIntVirtualCall, media - [<D>192.168.224.1:6014, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], NM:1, NP:1, ND:1, callID - 32117396073021927.
    .087 RequestMgResource: {MG20}[L:192.168.224.52, R:192.168.224.1], line #2[0], AcceptIntVirtualCall, media - [<D>192.168.224.52:6014, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], NM:1, NP:1, ND:1, callID - 32117396073021927.
    .091 ReceiveMediaStatistics: there is no CDR yet, MG{0}, sessID - 0
    -+- [L0.0.0.0:0 R0.0.0.0:0] TXP:0, TXC:N/A, TXPS:0, RXP:0, RXC:N/A, RXPS:0, RXL:0, RXJ:0, RXMD:0
    .094 InsertEndpoint: {MG0}<RTP/1003>[192.168.224.1:6016] - 32117396073021927.
    .096 ProcessMgReply: {MG0}, line #64, AcceptIntVirtualCall, RTP port - 6016, CAC result - OK, media - [<D>192.168.224.1:6014, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], callID - 32117396073021927.
    .113 InsertEndpoint: {MG20}<RTP/1002>[192.168.224.52:5004] - 32117396073021927.
    .115 ProcessMgReply: {MG20}, line #2, AcceptIntVirtualCall, RTP port - 5004, CAC result - OK, media - [<D>192.168.224.52:5004, a: PCMU(0), PCMA(8), G729(18), telephone-event(101)], callID - 32117396073021927.
    .118 TS: line #64(e:13) - OffHookInCall.
    .133 CreateFrameTask: type - AcceptInternalCall, callID - 32117396073021927.
    .134 ProcessFrameTask: type - AcceptInternalCall, line #64, callID - 32117396073021927.
    .135 InternalCallAccept: line #64[0](e:13), caller line #2, callID - 32117396073021927.
    .136 OnInternalCallAccept: caller line #2[0](e:12), called line #64[0], callID - 32117396073021927.
    .137 TS: line #2[0](e:12) - OffHookInCall.
    .138 EndTone: line #2(e:12), tone - None.
    .139 LaunchAutoResponder: line #64(e:13), PBX caller - 12, callID - 32117396073021927.
    .140 StartCallDetailLog: line #64[0](e:13), called party, callID - 32117396073021927.
    .158 CreateFileEndpoint: {MG0}<FILE/1004> - 32117396073021927.
    .159 MapDetectionEndpoint: DTMF detection RTP[>192.168.224.52:5004>(192.168.224.1:6016)]{MG0}<1003>, callID - 32117396073021927.
    .162 AcceptAdvFxsPBXCall(None): line #2[0](e:12), callID - 32117396073021927[5220264166803718973], media - [<D>192.168.224.1:6016, a: PCMU(0), PCMA(8), G729a(18), telephone-event(101)].
    .173 OpenVmStream(Playback): line #64[0], {MG0}32117396073021927<1>, FILE[/mnt/bbram/voicedata/13/greeting.wav, PC: 1, a: PCMU(0)] -> RTP[(192.168.224.1:6016)>192.168.224.52:5004>, a: PCMU(0)].
    .176 OpenVmStream(Playback): line #64[0], {MG20}32117396073021927<1>, RTP[>192.168.224.1:6016>(192.168.224.52:5004), a: PCMU(0)] -> FXS[0].
    .411 OnAdvFxsPBXCallDone(None): line #2[0](e:12), callID - 32117396073021927[5220264166803718973], media - [N/A].
    15:31:20.515 ProcessConnectionClosed(FileOver): {MG0}32117396073021927<1>, message for VMS(autoresponder), line #64[0](e:13), callID - 32117396073021927.
    .522 CloseVmStream(Playback): line #64[0], {MG0}32117396073021927<1>.
    .526 OpenVmStream(Playback): line #64[0], {MG0}32117396073021927<1>, FILE[/telephony/sysmessages/de_DE/startrectone.wav, PC: 1, a: PCMU(0)] -> RTP[(192.168.224.1:6016)>192.168.224.52:5004>, a: PCMU(0)].
    15:31:21.179 ProcessConnectionClosed(FileOver): {MG0}32117396073021927<1>, message for VMS(autoresponder), line #64[0](e:13), callID - 32117396073021927.
    .183 CloseVmStream(Playback): line #64[0], {MG0}32117396073021927<1>.
    .186 CreateFileEndpoint: {MG0}<FILE/1005> - 32117396073021927.
    .189 OpenVmStream(Record): line #64[0], {MG20}32117396073021927<2>, FXS[0] -> RTP[(192.168.224.52:5004)>192.168.224.1:6016>, a: PCMU(0)].
    .191 OpenVmStream(Record): line #64[0], {MG0}32117396073021927<2>, RTP[>192.168.224.52:5004>(192.168.224.1:6016), a: PCMU(0)] -> FILE[/mnt/bbram/voicedata/13//mailbox/mail1.wav, PC: 0, a: PCMU(0)].
    15:31:24.470 OnAdvFxsPBXCallClose: line #2[0](e:12), callID - 32117396073021927[5220264166803718973].
    .471 InternalCallClose: line #2[0](e:12), callID - 32117396073021927.
    .472 GetTrunkByCallID: erasing PBX callID 32117396073021927.
    .473 OnInternalCallClose: initiator line #2, target virtual line #64, callID - 32117396073021927.
    .473 CloseAutoResponder: line #64[0](e:13), callID - 32117396073021927.
    .476 StopCallDetailLog: line #64[0](e:13), callID - 32117396073021927.
    .476 UnmapDetectionEndpoint: DTMF detection {MG0}<1003>, callID - 32117396073021927.
    .478 EndMediaSession: {MG20} - 32117396073021927.
    .479 EraseEndpoint: {MG20}<RTP/1001>[192.168.224.52:5004] - 32117396073021927.
    .480 EraseEndpoint: {MG20}<RTP/1002>[192.168.224.52:5004] - 32117396073021927.
    .481 TidyMediaStatisticRequest: MG{0}, callID - 32117396073021927, sessID - 32117396073021927, remain records - 0.
    .483 EndMediaSession: RESET {MG20}.
    .487 <<<<<<<<<<<< Handle Map >>>>>>>>>>>>
    C:
    S:
    .487 EndMediaSession: {MG0} - 32117396073021927.
    .488 EraseEndpoint: {MG0}<FILE/1004> - 32117396073021927.
    .520 EraseEndpoint: {MG0}<FILE/1005> - 32117396073021927.
    .521 EraseEndpoint: {MG0}<RTP/1003>[192.168.224.1:6016] - 32117396073021927.
    .523 EndMediaSession: {MG0} - 32117396073021927, ownerID - 32117396073021927, requesting RTP statistics.
    .526 EndMediaSession: RESET {MG0}.
    .528 <<<<<<<<<<<< Handle Map >>>>>>>>>>>>
    C:
    S:
    -- E --
    .529 EraseVirtualTrunk: line #64(e:13).
    .543 CreateFrameTask: type - TidyMediaCore, callID - 0.
    .544 ProcessFrameTask: type - TidyMediaCore.
    .546 NewMailVisualIndication: line #3(e:13), new mails - 1, read mails - 0.
    .578 ATS: line #2(e:12) - OnHookSilent.
    .578 TS: line #2[0](e:12) - OnHookSilent.
    .587 ErasePBXCall: callID - 5220264166803718973.
    .591 ReceiveMediaStatistics: there is no CDR yet, MG{0}, sessID - 0
    -+- [L192.168.224.1:6016 R192.168.224.52:5004] TXP:328, TXC:PCMU, TXPS:80, RXP:644, RXC:PCMU, RXPS:160, RXL:0, RXJ:19, RXMD:39
    The line
    means that most probably the INVITE was rejected by the phone (probably "Busy Here" in answer to INVITE). You can look into SIP messaging to make sure it is the case. The reason of rejecting the call is not yet clear to me (maybe DND?).
    But first it worth to make sure the phone rejected the call. Call you look into SIP UA logs on the Quadro, or to the SIP Trace log on the Snom?
    I guess it's sending busy - I will test again and look at the SIP-Protokolls
    If you increase the amount of line appearances the telephone has in the ip line settings of the extension in the Epygi, see if that rectifies the problem.. default is 2 and they might be allocating somehow to the other 2 extension accounts... so increase it to three...
    This is just a thought....
    I increased line appearances to 3, still same issue.
    SIP UA log from Epygi:
    <<======================LOGS MARKER======================>>
    13:17:58 SipSessDlg: # Call ID Info # SID: 5220972028953589658 # 13:17:58 SipID: 5ba9795228d6085e557ac0223b0d7de8@217.114.78.114
    13:17:58 SipSessDlg::ChangeSessTimerFlag # user pepphone # SessionTimer = 0
    13:17:58 SipSessDlg::IncOptionsProc # Got OPTIONS message # OID: 255 # SID:
    5220972028953589658
    13:17:58 UA --> CM # RequestMedia # For user 511457 # SID: 5220972028953589658
    13:17:58 CM --> UA # OnResponseMedia # Media exist # OID: 255 # SID: 5220972028953589658
    13:17:58 SipSessDlg::TerminateTransactions # OID: 255 # SIPID: 5ba9795228d6085e557ac0223b0d7de8@217.114.78.114 # SID: 5220972028953589658
    13:18:01 SipSessDlg: # Call ID Info # SID: 5220972041838093486 # 13:18:01 SipID: 37bb06ea5407d4911e500c9d3f931e75@217.114.78.114
    13:18:01 SipSessDlg::ChangeSessTimerFlag # user pepphone # SessionTimer = 0
    13:18:01 SipSessDlg::IncOptionsProc # Got OPTIONS message # OID: 257 # SID: 5220972041838093486
    13:18:01 UA --> CM # RequestMedia # For user 511431 # SID: 5220972041838093486
    13:18:01 CM --> UA # OnResponseMedia # Media exist # OID: 257 # SID: 5220972041838093486
    13:18:01 SipSessDlg::TerminateTransactions # OID: 257 # SIPID: 37bb06ea5407d4911e500c9d3f931e75@217.114.78.114 # SID: 5220972041838093486
    13:18:01 SipSessDlg: # Call ID Info # SID: 5220972041838150406 # 13:18:01 SipID: 1332cb4a31c0492a312825615ee7f43f@217.114.78.114
    13:18:01 SipSessDlg::IncOptionsProc # Got OPTIONS message # OID: 259 # SID: 5220972041838150406
    13:18:01 UA --> CM # RequestMedia # For user 511458 # SID: 5220972041838150406
    13:18:01 CM --> UA # OnResponseMedia # Media exist # OID: 259 # SID: 5220972041838150406
    13:18:01 SipSessDlg::TerminateTransactions # OID: 259 # SIPID: 1332cb4a31c0492a312825615ee7f43f@217.114.78.114 # SID: 5220972041838150406
    13:18:12 Receive SIP message # (09/07/2008 11:18:12:219 GMT) # UDP # 896 bytes # from: 192.168.224.52:5060 # to: 192.168.222.100:5060
    INVITE sip:13@192.168.222.100 SIP/2.0
    Max-Forwards: 70
    Content-Length: 293
    Via: SIP/2.0/UDP 192.168.224.52:5060;branch=z9hG4bK3dfacccbd
    Call-ID: a18f6105894eb23
    From: Atelier Rieke <sip:ip-12@192.168.222.100>;tag=0c09f213ac41742
    To: sip:13@192.168.222.100
    CSeq: 2022945936 INVITE
    Supported: timer
    Session-Expires: 1200
    Allow-Events: talk, hold, conference
    Allow: INVITE,ACK,CANCEL,BYE,REFER,NOTIFY,MESSAGE,INFO
    Content-Type: application/sdp
    Contact: Atelier Rieke <sip:ip-12@192.168.224.52:5060;transport=udp>
    Supported: replaces
    User-Agent: Gigaset SL75 WLAN M5T SIP-UA SAFE/v3.6.4.8
    v=0
    o=MxSIP 0 1398639530 IN IP4 192.168.224.52
    s=SIP Call
    c=IN IP4 192.168.224.52
    t=0 0
    m=audio 5004 RTP/AVP 9 0 8 4 18 101
    a=rtpmap:9 G722/8000
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:4 G723/8000
    a=rtpmap:18 G729/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    13:18:12 Try to send SIP message # (09/07/2008 11:18:12:225 GMT) # UDP # 255 bytes # from: 192.168.222.100:5060 # to: 192.168.224.52:5060
    SIP/2.0 100 Trying
    To: <sip:13@192.168.222.100>
    From: "Atelier Rieke" <sip:ip-12@192.168.222.100>;tag=0c09f213ac41742
    Content-Length: 0
    13:18:12 TLayer::MsgToTU # Msg type: 51 # TID: 260 # DID: 0
    13:18:12 UACore::TLReqMsgProc # Got INVITE SIP request
    13:18:12 Try to send SIP message # (09/07/2008 11:18:12:245 GMT) # UDP # 434 bytes # from: 192.168.222.100:5060 # to: 192.168.224.52:5060
    SIP/2.0 401 Unauthorized
    Server: Epygi Quadro SIP User Agent/v4.1.58 (QUADRO-2X)
    WWW-Authenticate: Digest realm="quadro.home-epygi.de",nonce="a49b7459aefd7cac4d6ba49a3688888f" ,opaque="1215602292"
    Content-Length: 0
    13:18:12 Receive SIP message # (09/07/2008 11:18:12:332 GMT) # UDP # 340 bytes # from: 192.168.224.52:5060 # to: 192.168.222.100:5060
    ACK sip:13@192.168.222.100 SIP/2.0
    Max-Forwards: 70
    Content-Length: 0
    CSeq: 2022945936 ACK
    13:18:12 Receive SIP message # (09/07/2008 11:18:12:438 GMT) # UDP # 1100 bytes # from: 192.168.224.52:5060 # to: 192.168.222.100:5060
    Max-Forwards: 70
    Content-Length: 293
    Via: SIP/2.0/UDP 192.168.224.52:5060;branch=z9hG4bK8640c4712
    CSeq: 2022945937 INVITE
    Supported: timer
    Authorizationigest response="d4c31d7fb8b8f4078a7b6804e82d1cbe",userna me="ip-12",realm="quadro.home-epygi.de",nonce="a49b7459aefd7cac4d6ba49a3688888f" ,opaque="1215602292",uri="sip:13@192.168.222.100"
    Supported: replaces
    v=0
    s=SIP Call
    t=0 0
    a=fmtp:101 0-15
    13:18:12 Try to send SIP message # (09/07/2008 11:18:12:444 GMT) # UDP # 255 bytes # from: 192.168.222.100:5060 # to: 192.168.224.52:5060
    SIP/2.0 100 Trying
    Content-Length: 0
    13:18:12 TLayer::MsgToTU # Msg type: 51 # TID: 261 # DID: 0
    13:18:12 SipSessDlg: # Call ID Info # SID: 5220972089083093939 # 13:18:12 SipID: a18f6105894eb23
    13:18:12 SipSessDlg::ChangeSessTimerFlag # user ip-12 registered on UA # SessionTimer = 0
    13:18:12 SipSessDlg::ChangeSessTimerFlag # user ip-12 # SessionTimer = 0
    13:18:12 SipSessDlg::IncInviteProc # Got INVITE message # OID: 262 # SID: 5220972089083093939
    13:18:12 TargetQualifier::QualifyTargets # Try to qualify targets for dest 192.168.224.52 # OID: 262
    13:18:12 TargetQualifier::NatHandling # Don't need nat settings - direct reach # OID: 262
    13:18:12 UA --> CM # MakeCall # from: ip-12@192.168.222.100:, to: 13, child: (empty), media exist, GUID: (empty) # ContactInfo: 192.168.224.52 # SID: 5220972089083093939
    13:18:12 CallsAgent::OnMakeCall # MakeCall from CM # SID: 32825318352600159
    13:18:12 CallsAgent::OnMakeCall # Empty GUID from CM # SID: 32825318352600159
    13:18:12 SipSessDlg: # Call ID Info # SID: 32825318352600159 # 13:18:12 SipID: 32825318352600159_6f234538-8099-45e4....home-epygi.de
    13:18:12 SipSessDlg::ChangeSessTimerFlag # user R13 registered on UA # SessionTimer = 0
    13:18:12 SipSessDlg::ChangeSessTimerFlag # user R13 # SessionTimer = 0
    13:18:12 CM --> UA # MakeCall # from: 12, to: R13@192.168.222.23:2099, media exist # replaceSID: 0 # privacy: 0 # AlertInfo: not exist # AddInfo: [SP#192.168.224.1:5060][URIP#line=87f4329d][BND#R13] #OID: 263 # SID: 32825318352600159
    13:18:12 Display name == Atelier
    13:18:12 SipDlg:etermineInitTarget # Call to primary server # OID: 263
    13:18:12 TargetQualifier::QualifyTargets # Try to qualify targets for dest 192.168.222.23 # OID: 263
    13:18:12 TargetQualifier::NatHandling # Don't need nat settings - direct reach # OID: 263
    13:18:12 SipSessDlg::SelfMediaHandling # State: local offer, Peer Public Key: empty, SRTP flag: false, Sesssion Key: empty # OID: 263 # SID: 32825318352600159
    13:18:12 Try to send SIP message # (09/07/2008 11:18:12:835 GMT) # UDP # 931 bytes # from: 192.168.222.100:5060 # to: 192.168.222.23:2099
    INVITE sip:R13@192.168.222.23:2099;line=87f4329d SIP/2.0
    Via: SIP/2.0/UDP 192.168.222.100:5060;rport;branch=z9hG4bKEPSVBUS1d ebfbe8-b8d2-4ed0-acf6-3abd3710628b
    To: <sip:R13@192.168.224.1:5060>
    From: "Atelier" <sip:12@192.168.222.100>;tag=1215601384073bb8e0-f7b2-42da-9746-7c590c61f164
    CSeq: 248 INVITE
    Call-ID: 32825318352600159_6f234538-8099-45e4....home-epygi.de
    Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, UPDATE
    Contact: "Atelier" <sip:12@192.168.222.100:5060>
    Supported: replaces, norefersub
    User-Agent: Epygi Quadro SIP User Agent/v4.1.58 (QUADRO-2X)
    Max-Forwards: 70
    Content-Length: 232
    v=0
    o=12 210 373 IN IP4 192.168.222.100
    s=-
    c=IN IP4 192.168.222.100
    t=0 0
    m=audio 6012 RTP/AVP 0 8 18 101
    a=fmtp:101 0-15
    13:18:12 Receive SIP message # (09/07/2008 11:18:12:863 GMT) # UDP # 563 bytes # from: 192.168.222.23:2099 # to: 192.168.222.100:5060
    SIP/2.0 403 Use Proxy
    Via: SIP/2.0/UDP 192.168.222.100:5060;rport=5060;branch=z9hG4bKEPSV BUS1debfbe8-b8d2-4ed0-acf6-3abd3710628b
    CSeq: 248 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO
    Allow-Events: talk, hold, refer, call-info
    Supported: timer, 100rel, replaces, callerid
    Content-Length: 0
    13:18:12 TLayer::MsgToTU # Msg type: 403 # TID: 264 # DID: 263
    13:18:12 Try to send SIP message # (09/07/2008 11:18:12:872 GMT) # UDP # 486 bytes # from: 192.168.222.100:5060 # to: 192.168.222.23:2099
    ACK sip:R13@192.168.222.23:2099;line=87f4329d SIP/2.0
    CSeq: 248 ACK
    Max-Forwards: 70
    Content-Length: 0
    13:18:12 SipSessDlg::Inc4xxProc # Got 403 message # OID: 263 # SID: 32825318352600159
    13:18:12 SipSessDlg::ErrorHandling # Error: RequestRejected, Move to terminate state # OID: 263 # SID: 32825318352600159
    13:18:12 UA --> CM # ReportError # Error: RequestRejected # Sip error: 403 # SID: 32825318352600159
    13:18:12 SipSessDlg::TerminateTransactions # OID: 263 # SIPID: 32825318352600159_6f234538-8099-45e4....home-epygi.de # SID: 32825318352600159
    13:18:12 CM --> UA # OnRinging # Media not exist # OID: 262 # SID: 5220972089083093939
    13:18:12 Try to send SIP message # (09/07/2008 11:18:12:928 GMT) # UDP # 402 bytes # from: 192.168.222.100:5060 # to: 192.168.224.52:5060
    SIP/2.0 180 Ringing
    To: <sip:13@192.168.222.100>;tag=1215601384e308cd65-bde9-417d-8819-84ea2c0f5ea2
    Contact: <sip:13@192.168.224.1:5060>
    Content-Length: 0
    13:18:14 CM --> UA # OnAccept # Media exist # OID: 262 # SID: 5220972089083093939
    13:18:14 SipSessDlg::SelfMediaHandling # State: complete, Peer Public Key: empty, SRTP flag: false, Sesssion Key: empty # OID: 262 # SID: 5220972089083093939
    13:18:14 Try to send SIP message # (09/07/2008 11:18:14:114 GMT) # UDP # 782 bytes # from: 192.168.222.100:5060 # to: 192.168.224.52:5060
    SIP/2.0 200 OK
    Content-Length: 228
    v=0
    o=13 606 161 IN IP4 192.168.224.1
    s=-
    c=IN IP4 192.168.224.1
    t=0 0
    m=audio 6014 RTP/AVP 0 8 18 101
    a=fmtp:101 0-15
    13:18:14 Receive SIP message # (09/07/2008 11:18:14:334 GMT) # UDP # 596 bytes # from: 192.168.224.52:5060 # to: 192.168.224.1:5060
    ACK sip:13@192.168.224.1:5060 SIP/2.0
    Max-Forwards: 70
    Content-Length: 0
    Via: SIP/2.0/UDP 192.168.224.52:5060;branch=z9hG4bK4986b13d7
    CSeq: 2022945937 ACK
    13:18:14 TLayer::MsgToTU # Msg type: 55 # TID: 261 # DID: 262
    13:18:14 UACore::TLReqMsgProc # Got ACK SIP request
    13:18:14 SipSessDlg::IncAckProc # Got ACK message # OID: 262 # SID: 5220972089083093939
    13:18:14 UA --> CM # Done # media not exist # SID: 5220972089083093939
    13:18:29 Receive SIP message # (09/07/2008 11:18:29:076 GMT) # UDP # 638 bytes # from: 192.168.224.52:5060 # to: 192.168.224.1:5060
    BYE sip:13@192.168.224.1:5060 SIP/2.0
    Max-Forwards: 70
    Content-Length: 0
    Via: SIP/2.0/UDP 192.168.224.52:5060;branch=z9hG4bK57f0b7666
    CSeq: 2022945938 BYE
    Supported: timer
    Authorizationigest response="adf9469de97209ec69cbee1ef2104aad",userna me="ip-12",realm="quadro.home-epygi.de",nonce="a49b7459aefd7cac4d6ba49a3688888f" ,opaque="1215602292",uri="sip:13@192.168.224.1:506 0"
    Supported: replaces
    13:18:29 TLayer::MsgToTU # Msg type: 54 # TID: 265 # DID: 0
    13:18:29 UACore::TLReqMsgProc # Got BYE SIP request
    13:18:29 SipSessDlg::IncByeProc # Got BYE message # OID: 262 # SID: 5220972089083093939
    13:18:29 SipSessDlg::TerminateTransactions # OID: 262 # SIPID: a18f6105894eb23 # SID: 5220972089083093939
    13:18:29 UA --> CM # CloseCall # reason: Got BYE message # SID: 5220972089083093939
    13:18:29 Try to send SIP message # (09/07/2008 11:18:29:166 GMT) # UDP # 356 bytes # from: 192.168.224.1:5060 # to: 192.168.224.52:5060
    SIP/2.0 200 OK
    Content-Length: 0
    SIP log from Snom360:
    Received from udp:192.168.222.100:5060 at 24/12/2001 01:14:07:600 (931 bytes):
    CSeq: 248 INVITE
    Max-Forwards: 70
    Content-Length: 232
    v=0
    s=-
    t=0 0
    a=fmtp:101 0-15
    Sent to udp:192.168.222.100:5060 at 24/12/2001 01:14:07:612 (563 bytes):
    CSeq: 248 INVITE
    Content-Length: 0
    Received from udp:192.168.222.100:5060 at 24/12/2001 01:14:07:651 (486 bytes):
    CSeq: 248 ACK
    Max-Forwards: 70
    Content-Length: 0
    Received from udp:192.168.222.100:5060 at 24/12/2001 01:14:23:940 (622 bytes):
    NOTIFY sip:R13@192.168.222.23:2099;line=87f4329d SIP/2.0
    Via: SIP/2.0/UDP 192.168.222.100:5060;rport;branch=z9hG4bKEPSVBUS4a 9a36ff-8656-449e-81c5-b3b5efdd6952
    From: <sip:*0@192.168.222.100>;tag=121560138463365dd2-3829-4afe-8783-07134800106e
    CSeq: 305 NOTIFY
    Call-ID: 5f803f2f-a6b8-4d50-a232-569983a30e81....home-epygi.de
    Contact: <sip:*0@192.168.222.100:5060>
    Content-Type: application/simple-message-summary
    Max-Forwards: 70
    Event: message-summary
    Content-Length: 43
    Messages-Waiting: yes
    Voice-Message: 1/0
    Sent to udp:192.168.222.100:5060 at 24/12/2001 01:14:23:950 (535 bytes):
    Via: SIP/2.0/UDP 192.168.222.100:5060;rport=5060;branch=z9hG4bKEPSV BUS4a9a36ff-8656-449e-81c5-b3b5efdd6952
    CSeq: 305 NOTIFY
    Content-Length: 0
    Received from udp:192.168.222.100:5060 at 24/12/2001 01:14:29:172 (621 bytes):
    Via: SIP/2.0/UDP 192.168.222.100:5060;rport;branch=z9hG4bKEPSVBUS97 b1d70f-6b25-48d6-b0da-d3bb4f7a2609
    From: <sip:*0@192.168.222.100>;tag=1215601384599dd782-b310-4f3b-9846-b56b3b032623
    CSeq: 377 NOTIFY
    Call-ID: 0d1a0745-cec0-445d-8c0e-2b3646c6e4ba....home-epygi.de
    Max-Forwards: 70
    Content-Length: 42
    Messages-Waiting: no
    Voice-Message: 0/0
    Sent to udp:192.168.222.100:5060 at 24/12/2001 01:14:29:182 (535 bytes):
    Via: SIP/2.0/UDP 192.168.222.100:5060;rport=5060;branch=z9hG4bKEPSV BUS97b1d70f-6b25-48d6-b0da-d3bb4f7a2609
    CSeq: 377 NOTIFY
    Content-Length: 0
    This seems to be the crucial part:
    13:31:40 TLayer::MsgToTU # Msg type: 55 # TID: 395 # DID: 396
    13:31:40 UACore::TLReqMsgProc # Got ACK SIP request
    13:31:40 SipSessDlg::IncAckProc # Got ACK message # OID: 396 # SID: 5220975555121361360
    13:31:40 UA --> CM # Done # media not exist # SID: 5220975555121361360
    13:31:43 Receive SIP message # (09/07/2008 11:31:43:961 GMT) # UDP # 637 bytes # from: 192.168.224.52:5060 # to: 192.168.224.1:5060
    Max-Forwards: 70
    Content-Length: 0
    Via: SIP/2.0/UDP 192.168.224.52:5060;branch=z9hG4bK4eeb8e0ea
    Call-ID: 3ecbdda5cfa2a04
    From: Atelier Rieke <sip:ip-12@192.168.222.100>;tag=d40dfe4b018bad8
    To: <sip:13@192.168.222.100>;tag=12156013841a33e052-30cb-4eaf-8f9b-3f7112e070df
    CSeq: 824199322 BYE
    Supported: timer
    Authorizationigest response="730a129406518ea0e62f4a764419d43d",userna me="ip-12",realm="quadro.home-epygi.de",nonce="17c07d784187e63e9fd4abb3fab9a0a8" ,opaque="1215603097",uri="sip:13@192.168.224.1:506 0"
    Supported: replaces
    Nop, the crucial part is the "SIP/2.0 403 Use Proxy" answer from Snom. See the reaction of Quadro to that message:
    That means we consider this answer as a reject, and behave the same way as if receive "486 Busy here" or any other 4xx responce.
    The question is - why Snom sends such a responce. I have never met that before. Probably there is a wrong checkbox set in Snom config...
    And in general, there is something completely wrong in this phone's response...
    The response codes are wrong!!
    The code 403 is the code of "Forbibben" response, but not of "Use Proxy". "Use Proxy" should be the code 305.
    In other words there are "305 Use Proxy" and "403 Forbidden" allowed by protocol, but not "403 Use Proxy"..
    Most probably Quadro understands this response as "403 Forbidden" and of course, it terminates the transactions...
  1. Remote Extension problem!
    By acs@kems.net in forum Troubleshooting and Problems
    Last Post: 06-22-2008, 07:42 AM
  2. remote extension does not work
    By fpwgmbh in forum Troubleshooting and Problems
    Last Post: 04-29-2008, 05:42 AM
  3. Multi Extension Ringing and non virtual extensions
    Last Post: 01-21-2008, 05:09 PM
  4. Ringing Patterns
    By bragnet in forum 'How Do I' Questions
    Last Post: 08-30-2007, 05:21 PM
  5. To much time in the ringing between ext
    By mexel in forum Troubleshooting and Problems
    Last Post: 04-27-2007, 02:13 PM
