Thread: problem with datetime !!!
    Default problem with datetime !!!
    Good morning
    Sorry for my English translated by google!
    I have a problem with the script I always falls on the form "close", why?
    Sincerely yours!
    <?xml version="1.0" encoding="UTF-8"?>
    <vxml version="2.0">
    <var name="working_hours" expr="'0'"/>
    <form id="mainform">
    <noinput count="3">
    <prompt>
    <audio src="messagefin.wav" />
    </prompt>
    <exit/>
    </noinput>
    <object name="field1" classid="datetime">
    <filled>
    <if cond="datetime_hour &gt; '08'">
    <if cond="datetime_min &gt; '45'">
    <if cond="datetime_hour &lt; '12'">
    <if cond="datetime_min &lt; '10'">
    <assign name="working_hours" expr="'1'"/>
    </if>
    </if>
    </if>
    </if>
    <if cond="datetime_hour &gt; '13'">
    <if cond="datetime_hour &lt; '17'">
    <if cond="datetime_min &lt; '50'">
    </if>
    </if>
    </if>
    </if>
    <if cond="datetime_hour &gt; '20'">
    <if cond="datetime_min &gt; '30'">
    <if cond="datetime_hour &lt; '22'">
    <if cond="datetime_min &lt; '00'">
    </if>
    </if>
    </if>
    </if>
    <if cond="working_hours == '1'">
    <prompt> <audio src="messbienvenue.wav" /> </prompt>
    <goto nextitem="field2"/>
    <else/>
    <goto next="#fermer"/>
    </if>
    <exit/>
    </filled>
    </object>
    <field name="field2" type="digits?length=2" modal="false">
    <link dtmf="3" next="#curemenu"/>
    <link dtmf="5" next="#freres"/>
    <prompt timeout="5s">
    <audio src="messjoindreg.wav" />
    </prompt>
    <option dtmf="1" value="31" />
    <option dtmf="2" value="32" />
    <option dtmf="4" value="33" />
    <option dtmf="6" value="80" />
    <option dtmf="70" value="20" />
    <option dtmf="71" value="11" />
    <option dtmf="72" value="12" />
    <option dtmf="73" value="13" />
    <option dtmf="74" value="14" />
    <option dtmf="75" value="15" />
    <option dtmf="76" value="16" />
    <option dtmf="77" value="17" />
    <option dtmf="78" value="18" />
    <option dtmf="79" value="19" />
    <option dtmf="80" value="80" />
    <filled>
    <goto nextitem="field3"/>
    </filled>
    </field>
    <object name="field3" classid="connect">
    <param name="extension" expr="field2"/>
    <filled>
    <prompt> <audio src="messagefin.wav" /> </prompt>
    <exit/>
    </filled>
    <nomatch>
    <prompt> <audio src="messnomatch.wav" /> </prompt>
    </nomatch>
    <nomatch count="3">
    <exit/>
    </nomatch>
    </object>
    </form>
    <form id="curemenu">
    <noinput count="3">
    <assign name="sfield1" expr="'19'"/>
    <goto nextitem="sfield2" />
    </noinput>
    <field name="sfield1" type="digits?length=2" modal="false">
    <audio src="cure.wav"/>
    </prompt>
    <option dtmf="1" value="19"/>
    <option dtmf="2" value="20"/>
    <option dtmf="3" value="51" />
    <filled>
    <goto nextitem="sfield2"/>
    </filled>
    </field>
    <object name="sfield2" classid="connect">
    <param name="extension" expr="sfield1"/>
    <filled>
    <exit/>
    </filled>
    <nomatch>
    <goto nextitem="field1"/>
    </nomatch>
    <nomatch count="3">
    <exit/>
    </nomatch>
    </object>
    </form>
    <form id="freres">
    <noinput count="3">
    <prompt>
    </prompt>
    <exit/>
    </noinput>
    <audio src="freres.wav"/>
    </prompt>
    <option dtmf="1" value="13"/>
    <option dtmf="3" value="14"/>
    <option dtmf="4" value="19"/>
    <option dtmf="5" value="12"/>
    <option dtmf="6" value="15"/>
    <option dtmf="70" value="20"/>
    <option dtmf="72" value="12"/>
    <option dtmf="73" value="13"/>
    <option dtmf="74" value="14"/>
    <option dtmf="75" value="15"/>
    <option dtmf="79" value="19"/>
    <filled>
    </filled>
    </field>
    <filled>
    <exit/>
    </filled>
    <nomatch>
    </nomatch>
    <nomatch count="3">
    <exit/>
    </nomatch>
    </object>
    </form>
    <form id="fermer">
    <noinput count="3">
    <prompt>
    </prompt>
    <exit/>
    </noinput>
    <audio src="pasderanger.wav"/>
    </prompt>
    <option dtmf="1" value="11"/>
    <filled>
    </filled>
    </field>
    <filled>
    <exit/>
    </filled>
    <nomatch>
    </nomatch>
    <nomatch count="3">
    <exit/>
    </nomatch>
    </object>
    </form>
    </vxml>
    forgiveness, this is not the form "close" but the form "fermer" !!!
    The following example plays match.wav if current time is in 13:15 to 14:45 range, otherwise - nomatch.wav.
    I put comments inside to help you out to understand the routine.
    Hope it helps.
    <noinput count="3">
    <prompt> <audio src="timeover.wav" /> </prompt>
    <exit/>
    </noinput>
    <var name="match" expr="'0'"/>
    <form id="datetimeform">
    <filled>
    <!-- MATCH HOURS FIRST -->
    <if cond="datetime_hour &gt; '12'">
    <if cond="datetime_hour &lt; '15'">
    <assign name="match" expr="'1'"/>
    </if>
    </if>
    <if cond="match == '1'">
    <!-- HOURS ARE MATCHED, NOW MATCH MINUTES -->
    <if cond="datetime_hour == '13'">
    <if cond="datetime_min &lt; '15'">
    <assign name="match" expr="'0'"/>
    </if>
    </if>
    <if cond="datetime_hour == '14'">
    </if>
    </if>
    </if>
    <!-- FINALLY, IF MATCH PLAY MATCH.WAV, OTHERWISE - NOMATCH.WAV -->
    <prompt> <audio src="match.wav" /> </prompt>
    <else/>
    <prompt> <audio src="nomatch.wav" /> </prompt>
    </if>
    <exit/>
    </filled>
    </object>
    </form>
    </vxml>
    ________
    Suzuki gsx series
    ________
    Prilosec Death
    Thank you very much for your answer, it works!
    But I would add 2 slices of schedule more: 8:45 to 12:10 and 20:30 to 22:00!
    How we do?
    Sincerely yours!
    Well, I am far from being VXML guru, but please try the following terrible piece of code (I don't know if VXML allows to write the same logic more beautifully...) :
    <filled>
    <!-- from 08:45 to 08:59 -->
    <if cond="datetime_hour == '8'">
    </if>
    </if>
    <!-- from 09:00 to 11:59 -->
    <if cond="datetime_hour &gt; '8'">
    </if>
    </if>
    <!-- from 12:00 to 12:09 -->
    <if cond="datetime_hour == '12'">
    </if>
    </if>
    <!-- from 13:45 to 13:59 -->
    </if>
    </if>
    <!-- from 14:00 to 16:59 -->
    </if>
    </if>
    <!-- from 17:00 to 17:49 -->
    <if cond="datetime_hour == '17'">
    </if>
    </if>
    <!-- from 20:30 to 20:59 -->
    <if cond="datetime_hour == '20'">
    </if>
    </if>
    <!-- from 21:00 to 21:59 -->
    </if>
    </if>
    I didn't test this code at all, just wrote it , so it may have typos or anything else. This is just to show you one possible way to program that.
    Cheers,
