Thread: call routing
    Default call routing
    Ok have several issues am trying to work out..
    The scenario is as follows:
    Office in Japan using an ITSP based in Australia (Pennytel) for local calls in Japan.
    This is due to the cost of the ITSP in Aust being cheaper than anything I can find here in Japan.
    Rules are:
    1.Users when dialling numbers inside Japan just dial the number as per normal PSTN. Then these calls are routed by Pennytel.
    2. When users need to dial overseas then they use 7 before the number (7+1 30312345)
    Problems I am having is the DID number from Pennytel is showing when calling how can I hide it or preferably show the original caller id (the PSTN number in Japan)?? I dont want customers thinking they are being called from Australia...
    Quote Originally Posted by mjnorris View Post
    Rules are:
    If you are using an Australian ITSP .. to dial back into Japan ? well if it is using the Australian telephone lines... you might... might be able to use 1831 as a prefix to your telephone numer to block the number from being presented to your caller...
    1831 = Caller Number Display block
  1. Inbound call routing ISDN 2xi
    By Legassick in forum 'How Do I' Questions
    Last Post: 04-10-2008, 01:10 AM
  2. IVR to call routing table
    By andy.collins in forum VXML Scripting on Quadro
    Last Post: 10-02-2007, 07:24 AM
  3. Prefix Tag on call Routing
    Last Post: 06-27-2007, 10:09 PM
  4. Call routing based on incoming DID
    By wesleyit in forum 'How Do I' Questions
    Last Post: 12-03-2006, 02:15 PM
  5. Call Routing giving me frustration
    By ATLANTIC in forum 'How Do I' Questions
    Last Post: 10-20-2006, 02:04 AM
