Thread: Bypass Auto attendant
    ediggin
    Guest
    Default Bypass Auto attendant
    Hi
    How do I bypass the auto attendant with the ISDN version of the Quadro 2xi, I read the following post but the FXO option says that there is no FXO ?
    "By default all calls from PSTN are routed to Auto Attendant. You can change that from "Telephony -> FXO Settings" page and route all PSTN calls to the desired extension. lets say, ext. 11. Then to be able to ring all the phones together on incoming PSTn calls you need to enable Many Extension Ringing service on the ext.11. Click on ext. 11 on the "Users -> Extensions Management", then go to "Supplementary Services -> Caller ID Based Services" page, click on "Any Address", choose "Many Extension Ringing" and enable it. Then choose the phones that you want to ring on incoming calls and enable them too."
    Ed
    It will be in the set up of the ISDN section of your line.... routing within the isdn wizard will be pointing to your 00 default aa
    It should be under Telephony-->ISDN settings ( just under FXO )
    The description cited above by you is for Quadros with FXO ports. "FXO Settings" page isn't available on the ISDN Quadros. You should go to "Telephony -> ISDN Settings" page, click on Trunk and choose the extension to which you want to route all the calls from ISDN, or you can choose the "Routing with inbound destination number" option.
  1. Auto attendant
    By bsnquadro in forum 'How Do I' Questions
    Last Post: 11-16-2012, 12:30 AM
  2. IVR menu a Auto Attendant extension
    By skyways in forum 'How Do I' Questions
    Last Post: 09-03-2008, 10:39 AM
  3. Can’t access new auto attendant
    By derrickconner in forum Troubleshooting and Problems
    Last Post: 11-28-2006, 04:18 AM
  4. auto attendant audio codec
    By ayenacom in forum 'How Do I' Questions
    Last Post: 11-23-2006, 07:31 AM
  5. Night Switch Script for Auto Attendant
    By megatron in forum 'How Do I' Questions
    Last Post: 09-22-2006, 09:17 AM
