Thread: Quadro 2xi <-> 2xi T.38 faxing not working
    Oct 2006
    HORNSBY, NSW, Australia
    122
    Default Quadro 2xi <-> 2xi T.38 faxing not working
    Howdy,
    I'm trying to get Quadro 2xi <-> 2xi T.38 fax working.
    Below is a fax machine SIP to fax machine SIP call. It answers then immediately goes back to dial-tone again.
    "WorkFax" <27@58.96.27.194> "HuntFax" 37
    Codec: PCMA, Quality: 1 (excellent)
    Close Reason: CM note: "Not Supported"
    Note it doesn't recognise its a fax call, (it should have FAX).
    Below is an outgoing fax machine call via our ITSP:
    "WorkFax" 12 0392701122@sip00.mynetfone.com.au:5060
    RX Codec: PCMA,TX Codec: G729a, Quality: 1 (excellent), FAX
    Note FAX in the log.
    Testing using a Quadro 2xi -> 16x *does* work.
    Below is a fax machine SIP to voicemail call:
    "WorkFax" <27@58.96.27.194> "PilkoFax" 67
    Codec: G729a, Quality: 2 (good)
    Close Reason: MG note: FAX close
    started VMS, FAX
    Once again, note FAX in the log.
    Trust this helps.
    TECHNICAL APPENDIX:
    Firmware:
    2xi 4.1.40
    16x 4.1.40
    If T38 FAX works between 2xi and 16x devices, then it must work between two 2xis as well. I think the matter is in your Quadros setup/configuration. Please open a TSS ticket with the Quadro logs and our guys will give a solution after investigating them.
    By the way, please upgrade your Quadros to the latest 4.1.52 that you can find in our WEB.
    Oct 2006
    122
    Quote Originally Posted by aramk View Post
    ...Please open a TSS ticket with the Quadro logs and our guys will give a solution after investigating them...
    How do I open a TSS ticket?
    I've looked everywhere on the website & can't find any links.
    The TSS ticket logging procedure is the following. If you are an Epygi Distributor/Reseller, the you can open a TSS ticket from Channel Portal Login in our website. There must be a special link for TSS tickets submitting. If you are an End-User, then you'll not have that link on login, but you can ask you Distributor/Reseller to open a ticket on your behalf. You need to describe the problematic situation and the FAX call path (caller/called numbers).
    Quadro logs can be downloaded from "System -> Diagnostics -> Show System Logs -> System Logs Settings" page by pressing "Download all logs" button. "Enable Developer Logging" must be enabled. Just reproduce the problem, then download the system logs and attach to the TSS ticket. Our TSS guys will handle the ticket and will back with answers/suggestions.
  1. IPphone extintion not working
    By ahmed79 in forum Troubleshooting and Problems
    Last Post: 02-29-2008, 07:47 AM
  2. Outbound faxing
    By rhysw in forum Suggestions and Feedback
    Last Post: 04-24-2007, 05:21 PM
  3. Faxing Issues With ISDN Gateway
    By island in forum Hardware Interoperability
    Last Post: 04-12-2007, 12:29 AM
  4. VXML script not working,
    By ibisadmin in forum VXML Scripting on Quadro
    Last Post: 01-25-2007, 08:45 PM
  5. CID not working
    By alraiky in forum 'How Do I' Questions
    Last Post: 09-23-2006, 06:16 AM
