Thread: Busy Call Forwarding
    Nov 2007
    drummondville
    20
    Default Busy Call Forwarding
    I want forward all call when they busy.
    My phone is aastra 9133i with quadro 2x.
    In "Caller ID Based Services" of my extension, I have activated "Busy Call Forwarding". But when I call, they not forward they ring on line2.
    How forwarding call when I busy on another line.
    thanks
    That's because a Call Waiting feature is active on you extension and your phone isn't actually busy, even if there is one active call. In that case you'll receive the second call via call waiting. To make the Busy Call Forwarding work you either need to disable Call Waiting on that particular extension, or you can set the "Line Appearance" to 1 on the corresponding IP-Line (it means, that only one call at a time will be directed from Quadro to IP-Phone).
    Nov 2007
    drummondville
    20
    Thanks, the call forwarding is working.
    Can I make starting voicemail of first extension if nobody takes call forward? Not the voicemail on forward extension.
    No, it's not possible. Of couse, you can activate a "No answer Call Forwarding" on the second extension to the first extension, so if nobody will answer to the forwarded call, the call will back to the first extension again, or you can route it direct to the first extension's voicemail, but I don't think that it is correct solution for your case. You can also enable a SMS or E-mail notification on Busy Forwarding for your extension, so you'll be notified that a call was forwarded while the extension were busy.
  1. Call forwarding fails
    By Franz in forum Troubleshooting and Problems
    Last Post: 12-18-2012, 11:57 PM
  2. Call Forwarding
    By jscobbie in forum 'How Do I' Questions
    Last Post: 12-20-2007, 01:15 AM
  3. Call forwarding or divert
    Last Post: 11-25-2007, 03:28 PM
  4. FXS port on unending Call state: Busy
    By todash in forum Troubleshooting and Problems
    Last Post: 08-19-2007, 03:49 PM
  5. Three way calling for call forwarding
    By pdsguam in forum General Discussions
    Last Post: 06-07-2007, 05:33 AM
