Hi There,
I have two problems, i have an 2xi pbx running firmware 4.1.50 and the fx0 gateway running its latest firmware, i am not using the isdn side of the 2xi but am using three fxo ports for incoming and outgoing lines.
Problem1:
when an incoming call comes into reception phone, all works fine, that call is then transferred to another extension, if that call is ended by the outside caller before the extension is picked up, the extension keeps ringing and ringing and if you pick the call up it is dead....
Problem 2: (might be related)
An incoming call come into reception, if the call is ened by the outside caller before reception picks up it still rings for about 3 rings before the call is closed...
regards,
shaun
