Thread: Epygi QX50 1 way audio only over Peplink VPN, Want 2 Way
    Default Epygi QX50 1 way audio only over Peplink VPN, Want 2 Way
    Greetings, I recently installed an Epygi QX50 VOIP server in my office, with Yealink T48s phones. I have a Peplink Balance 305 router at the office and Peplink Balance One at home, which provides me a Peplink pepVPN between my home and office.
    (TLDR - T48s user can hear, but no one can hear user)
    I have attempted to use of my Yealink T48s phones at my home as an extension to the system. Everything works EXECEPT for Microphone audio from the the person using the phone. The phone user can hear the caller, but the mic audio of the user is not transmitted. (TLDR - T48s user can hear, but no one can hear user)
    Tutuapp https://9apps.ooo/https://showbox.software/
    I have created rules in the peplink firewalls for incoming, outgoing and internal firewall, on both ends. I created a blanket rule to allow all traffic between the two networks. (I have tried the phone onsite at the office, and all audio works when connected to the same lan as the QX50)
    In searching the Epygi forums, I found several similar older posts (5+ years old) that had issues with one-way audio. However, there was never any resolution posted.
    Anyone with a similar experience, or have any ideas?
    Thank you for reading.
    Hello Ameerjaiswal.
    Hope you are doing well.
    Could you add home office private IP address in NAT Exception list?
    TO do so navigate TELEPHONY-->NAT TRAVERSAL-->EXCEPTION and add it.
    Tigran
    Post firewall issue
    This is probably a firewall issue. The audio stream uses different ports than the phone registration. You need to open ports 5060 to 5064 and 10,000 to 20,000 for SIP. Those inbound ports need to be open on both routers for two way communcation. Showbox for PC
    Quote Originally Posted by ethannoah View Post
    This is probably a firewall issue. The audio stream uses different ports than the phone registration. You need to open ports 5060 to 5064 and 10,000 to 20,000 for SIP. Those inbound ports need to be open on both routers for two way communcation. tvtap
    Hello ethannoah,
    I'm totally agreed with you. It's a firewall issue. Please suggest some good tips for solve this sttuf.
    Thanks in Advance, Regards, Radul
    Thank you for your analysis. Looking forward to reading more of your posts. I hope to give something back and help others like you aided me.
    blackmart lucky patcher Dosti shayari freedom apk showbox apk download vidmate cartoon HD download popcorn time download mobdro download terrarium TV download videoder download Romantic shayari
    Default Question
    Yes! It is firewall issue. But if we disable firewall the chances of virus attack will increase. How can we deal with this issue?
    Can you post your Call Routing Table here?
    Or PM to me?
  1. QX50 ITSP Password Issue
    By thodgen in forum 'How Do I' Questions
    Last Post: 07-10-2019, 02:41 AM
  2. P-Asserted-Identity not passed through Qx50
    By df in forum 'How Do I' Questions
    Last Post: 08-08-2018, 02:13 PM
  3. QX50 Extension length
    By Phase1 in forum 'How Do I' Questions
    Last Post: 11-25-2015, 05:25 PM
  4. VPN From Epygi -> Sonicwall
    By yellowgrid in forum General Discussions
    Last Post: 05-17-2013, 01:25 PM
  5. VPN registered handset no audio
    By Legassick in forum Troubleshooting and Problems
    Last Post: 11-17-2008, 05:42 AM
