Thread: Trunk setup problems
    Default Trunk setup problems
    I have M32 with the couple of trunks operating fine for many years. Recently i obtained local trunk to cover some unreachable countries.
    I set it up as usual and it registers on their server, unfortunately calls get rejected.
    Problem is that local phone login name is passed to server (let we say 4001), but they request our phone number instead.
    See reply below...
    "From: "08555555" <sip:4001@sip5.teletek.se>;tag=15....
    We need to get the number 08555555 written where it now says 4001. Can you fix this? Like <sip:08555555@sip5.teletek.se>;tag=15....."
    I tried many things and only one phone can be set up (Extension/SIP Settings/User Name / DID Number 08555555).
    And then it works, unfortunately if i try to set another extension with above setting, it gets rejected with "User name already exist"
    Any ideas?
    Problem solved!
    Create a new route, use on page 2 (Routing Call Settings/Edit Entry) ITSP login name and the password but UNTICK "Keep Original Caller ID ".
    Finish and go to Edit Virtual extension you just used in the new route (997 or similar, created for the new trunk which you are going to use in that route). For the "SIP Settings/User Name / DID Number " use phone number (FE 08555555) and for the "SIP Advanced Settings/Authentication User Name" use ITSP supplied Logon name. That's all.
    SIP trunking can be a cheaper solution than traditional ISDN but there may be further initial outlay involved. There are companies out there who will sell you the benefits of SIP and fail to tell you that your system may not be suitable cleanmaster
  1. DID Setup
    By marinus in forum 'How Do I' Questions
    Last Post: 06-13-2013, 08:03 AM
  2. DID setup
    By zet in forum 'How Do I' Questions
    Last Post: 04-17-2013, 06:55 AM
  3. Trunk
    By Ricardo in forum 'How Do I' Questions
    Last Post: 03-30-2012, 09:37 AM
  4. Tunnel V Trunk
    By debjy in forum Troubleshooting and Problems
    Last Post: 10-31-2007, 04:06 PM
  5. Sip trunk to Sip Trunk transfer
    By definitel in forum Problem Report
    Last Post: 03-31-2007, 01:09 PM
