Results 1 to 1 of 1
Thread: Quadro 4L Snom outgoing call issue - Temporarily not available
    Default Quadro 4L Snom outgoing call issue - Temporarily not available
    Good day,
    I am currently having an issue making outgoing calls from newly manually provisioned phones:
    The client has a Quadro 4L FW version: 5.3.14. I have manually configured a new Snom 715 on the system with FW version:8.7.5.13.
    There are only 2 PSTN lines attached and they are configured with Key System Emulation; SLA1 is connected to FXO1 and SLA2 is connected to FXO 2. Other Snom 320's are working fine and can call out without problems.
    The Snom 715 I am trying to currently get working is setup as follows:
    Identity 1 is the internal extension which works fine.
    Identity 2 is setup as a shared line (SLA1) which has a corresponding function key configured.
    Identity 3 is setup as a shared line (SLA2) which also has a corresponding function key configured.
    If a user picks up the handset and presses the function key for either SLA1 or SLA2 and dials a number, they get a busy tone and the message Temporarily not available appears on the screen.
    I have attached a SIP Trace and PCAP Trace as well.
    Any assistance with allowing this phone to be able to call out would be greatly appreciated.
    Attached Files Attached Files
  1. Phone Call Forwarding : 302 Moved Temporarily
    By alloy in forum Troubleshooting and Problems
    Last Post: 05-11-2015, 05:48 AM
  2. Outgoing call issue
    By Dataworks in forum Troubleshooting and Problems
    Last Post: 04-17-2013, 01:29 PM
  3. ITSP outgoing call issue "Not Supported"
    By woods in forum Troubleshooting and Problems
    Last Post: 02-28-2012, 12:15 AM
  4. Quadro 4x + Snom m3 = 480 Temporarily not available
    By squiretech in forum Troubleshooting and Problems
    Last Post: 08-02-2010, 08:12 AM
  5. Quadro M32x and snom 320 function key issue
    By lambsons in forum Troubleshooting and Problems
    Last Post: 12-05-2008, 05:22 AM
Tags for this Thread
