Thread: T1 Gateway ECM for fax
    Default T1 Gateway ECM for fax
    Is there a method for turning off ECM in the Quadro T1 Gateway. I don't seem to find it.
    I have an issue with Freeswitch T.38. With another brand of gateway I was able to resolve by turning ECM off. Just need to find it in the Eqygi gateway.
    United States
    54
    When the E1/T1 Gateway makes a SIP call it will use the Codec settings from the Auto Attendant extn 00. Go to Extensions Management and then access the Codec settings using the link on the right for extn 00. You can disable the T.38 protocol on the codecs page. Make sure G.711 is the only enabled codec.
    And
  1. IP Fax Driver or a Fax Modem?
    By Logic in forum 'How Do I' Questions
    Last Post: 10-06-2011, 08:52 AM
  2. Send unified fax message from mailbox to fax machine
    By yobtrams in forum 'How Do I' Questions
    Last Post: 05-20-2009, 06:56 AM
  3. Faxing with the new ECM and 5.1
    By KSComs in forum General Discussions
    Last Post: 10-31-2008, 03:26 PM
  4. T.38 fax gateway?
    By sweni in forum 'How Do I' Questions
    Last Post: 10-15-2008, 09:07 AM
  5. Fax Receive to Email with no actual fax
    By timmeah in forum 'How Do I' Questions
    Last Post: 05-16-2008, 09:05 AM
