Results 1 to 1 of 1
Thread: Many Extension Ringing issue
    Default Many Extension Ringing issue
    On a 2xi running the latest 5.3.23 firmware, there are 7 IP lines and one FXS line provisioned and connecting to it. Calls between extensions are working fine, as well as calls using the ISDN and VoIP trunks provisioned.
    There is however one issue with inbound calls. Extension 99 used by one of the VoIP ITSPs has in its' "Caller ID Based Services for Any Address" the "Many Extension Ringing" feature enabled to ring concurrently on 6 extensions. One more IP Line and one FXS line are attached, but any attempt to enable one or both of the two lines, yields the following error message in red: "Maximum number of enabled records should not be more than 16".
    • What kind of limit gets hit by trying to add one more extension to the Many Extension Ringing group?
    • To which records is the error message referring to?
    Any ideas, where this limitation stems from?
  1. Many extension ringing after 5pm... This can be done?
    By Glennchot in forum General Discussions
    Last Post: 08-20-2013, 10:16 PM
  2. Answering PSTN call from non-ringing extension
    By pjetson in forum 'How Do I' Questions
    Last Post: 07-27-2012, 05:11 AM
  3. Attendant Ringing Announcement Issue
    By MEDIAPCSYSTEM in forum Troubleshooting and Problems
    Last Post: 06-15-2010, 12:36 PM
  4. Many extension ringing
    By ayenacom in forum 'How Do I' Questions
    Last Post: 03-30-2009, 11:44 AM
  5. Remote extension not ringing
    By mountrcg in forum Troubleshooting and Problems
    Last Post: 07-10-2008, 03:00 PM
Tags for this Thread
