At the moment i am using Grandstream 5024 and the set-up is substantially different..
Now I want to switch to Epygy Quadro M32 and so far i lost a lot of time to do it right..managed to understand extension,line,user combination so i have all working except i don't understand how to set incoming route..if i set it to go through the routing table i get engaged number..if i switch to unconditional forwarding, extension rings..but that is not the solution i want..
I have simple office setup..12 phones 95 percent outgoing calls two Voip providers one incoming number..i would like that incoming call rings all extensions, and then on the basis of the incoming number, executive in charge of the country from where call is coming, should pick the call up or transfer it to someone else...
Example of the route would be a great help..or if someone knows any manual/training/book for the Epygi i would be grateful ( i downloaded official manuals and anything i can find on epygi forums/site but unfortunately that particular area of setting up routes is not covered well in my opinion or i am slightly stupid)..
