Thread: General PIN Code
    Default General PIN Code
    Hello
    I like to know if it is possible to configure a General PIN Code, Only one PIN Code to all users to outings calls, instead of one pin to each user.
    How can I do it?
    Thanks..
    Actually the PIN codes are applicable to the call routing rules. So if you configure a PIN code to a specific routing rule for outgoing calls then all users have to use that PIN code when using that routing rule. How to do it:
    In the Local AAA Table add a PIN code,
    Run the wizard for the selected routing rule and in the second page for call routing wizard activate the Local Authentication check box,
    Use the "Users List" link for that routing rule and enable the PIN code for that routing rule.
    That's it
  1. PIN Code Issue
    By marinus in forum 'How Do I' Questions
    Last Post: 05-27-2013, 08:58 AM
  2. PIN Codes on Call Logs.
    Last Post: 09-03-2011, 01:46 PM
  3. PIN Code Dialing
    By Riaan.Brits in forum 'How Do I' Questions
    Last Post: 07-08-2010, 09:41 AM
  4. pin protect specific numbers
    Last Post: 11-14-2008, 02:41 PM
  5. Silence when Dialing out with pin code
    By lambsons in forum Troubleshooting and Problems
    Last Post: 04-14-2008, 02:20 AM
