Thread: PIN Code Issue
    Unhappy PIN Code Issue
    Hi All
    I've got an issue with PIN Codes on an Epygi Quadro M12Li. I've setup a Call Routing rule for testing which forces users to enter a predefined PIN code if they wish to dial an out side line (ISDN Line). The rule works but what happen is when the person answers the phone it disconnects the call. The rule looks like this:
    Enabled 7* NDS: 1 ISDN trunk: ISDN Trunk4, Timeslots: 1,2 None Loc.Auth.Users List
    The call statistics reports the following: Codec: PCMU, Quality: 1 (excellent) Authenticated by: PIN code PSTN call Close Reason: "Not Supported"
    Any advice on what the problem could be? If I don't use the PIN the call goes through.
    There was a problem with PIN code in QuadroM12Li with FW 5.2.37 and lower. The FW versions 5.3 are free of this problem. Please check what FW version in running on your Quadro and advice.
    Thanks for the response. The firmware version is 5.3.23 and the boot loader is 5.2.22.
    If you are a registered user then report regarding this issue to epygi TSS support with a ticket. If not, then go to the system-diagnostics-system logs-system log settings, mark all logs with a comment, repeat this scenario, download all logs and attach to this tread
  1. Interference issue, Pick up group issue and transfer issue
    By zet in forum Troubleshooting and Problems
    Last Post: 12-13-2012, 10:54 PM
  2. Client Code Rule for billing
    By lambsons in forum 'How Do I' Questions
    Last Post: 09-01-2011, 02:12 PM
  3. Analog line1 outbound call issue
    By hwan5758 in forum Troubleshooting and Problems
    Last Post: 11-05-2010, 04:08 AM
  4. PIN Code Dialing
    By Riaan.Brits in forum 'How Do I' Questions
    Last Post: 07-08-2010, 09:41 AM
  5. Silence when Dialing out with pin code
    By lambsons in forum Troubleshooting and Problems
    Last Post: 04-14-2008, 02:20 AM
