Thread: Paging question
    Default Paging question
    Hi all,
    I wanted to know if there is a way for paging not to interrupt people when they are on the phone, because it seems when they are talking to someone and they are paged, not only do they hear them, but it also breaks up the call.
    Also the other person who they are talking to, also hears the paging message.
    How can I prevent this?
    Krs,
    Vernon
    Paging doesn't interrupt the active call, but just introduced on the phone as the second call. So if someone in on the phone and is paged he/she can put the first call on hold and switch to the paging
    Thx Ashot, I will check it out.
    Krs,
    Zet
    Default hi...here is some info for you
    About nonpaged pool
    The nonpaged pool is memory which always resides in physical memory – it is never paged out. It is used by the kernel and also by device drivers installed on a system to store data which might be accessed in situations when page faults are not allowed. The amount of memory allocated to the nonpaged pool varies, and is determined as a function of operating system, processor architecture, and physical memory size. For example, 32-bit operating systems, with their smaller address spaces, have lower limits:
    32-bit Windows Server 2003 with 2GB or more of RAM will have a nonpaged pool limit of 256MB
    32-bit Windows Server 2008 will have a nonpaged pool limit of either 2GB or slightly more than 75% of physical memory, whichever is smaller
    64-bit operating systems, which have a much larger address space, have higher limits:
    64-bit Windows Server 2003 will have a nonpaged pool of either 128GB or 40% of physical memory, whichever is smaller
    64-bit Windows Server 2008 (or 2008 R2) will have a nonpaged pool limit of either 128GB or slightly more than 75% of physical memory, whichever is smaller
    signage
    Hoarding In U.P
  1. Paging issue and questions
    By zet in forum Troubleshooting and Problems
    Last Post: 05-01-2013, 09:55 AM
  2. Issue with QX1000 Paging Group
    By jaimeleon in forum Troubleshooting and Problems
    Last Post: 02-13-2013, 01:00 PM
  3. Problem Paging with SPA921
    By comedag in forum Troubleshooting and Problems
    Last Post: 09-20-2010, 12:38 PM
  4. Paging with Polycom
    By serviplexSIP in forum 'How Do I' Questions
    Last Post: 03-25-2009, 02:19 PM
  5. possible problem with paging group and watched extensions
    By harryb in forum Troubleshooting and Problems
    Last Post: 11-26-2008, 08:57 AM
