Thread: Hot desking
    Default Hot desking
    Hi All,
    I have a M8L and I'm setting up hot desking for all extensions, so what i have done is attached a snom phone to a IP line and enabled hot desking but I haven't attached an extension
    The extension registers to the IP Line with no extension number (which is fine), then i dial *78 login as an extension. but the problem is on the display of my snom phone it doesn't display the logged in extension number i only get (Ext.) on the display
    what i would like on the display is (Ext.) if the phone is logged out that's great but when logged in to an extension to display the extension number (Ext. 200)
    I would like to make it easy for the customer as i know i will get complaints if it doesn't display the correct extension number
    thanks
    leigh
    Default Hot Desking
    I have setup hot desking on a M8L all work very well but the only thing the customer would like is for the display on the Snom720 phone to display the login extension number, at the moment all that's on the display is Ext.
    so when logged out Ext. is great
    when logged in Ext. 200 for example
    thanks
    leigh
    makes perfect sense, thank you for suggestion. We'll add that to our todo list.
  1. Hot Desk and Remote Extension
    By cwatt in forum 'How Do I' Questions
    Last Post: 10-22-2010, 06:24 AM
  2. Hot Desking and incoming calls
    By ediggin in forum 'How Do I' Questions
    Last Post: 07-12-2010, 11:55 AM
  3. Hot Call Configuration
    By andyfox in forum Suggestions and Feedback
    Last Post: 07-07-2010, 11:50 AM
  4. Hot Calls
    By AaronPearl in forum General Discussions
    Last Post: 02-26-2010, 12:39 PM
  5. Locking and unlocking IP Phones
    By afripayments in forum Tips and Tricks
    Last Post: 10-21-2007, 07:41 PM
