Thread: Unconditionnal Call forwarding failure from external call
    Default Unconditionnal Call forwarding failure from external call
    Hi, I have an issu whit the Unconditionnal call forwarding.
    When I set call forwarding ON (*4) to external number (cell phone) the call from the IP-PSTN line doesn't work. But I it work when the call is from local extention.
    From IP-PSTN: all incoming call go to extention 2021
    Call routing paterne is * from PBX
    call forwarding number set to 450779XXXX
    I have try to set call routing from All but this still doesn't work.
    Any idea??
    This issue is come after the update 5.3.5
    Now I'm on firmware 5.3.11
    I use a Quadro2x
    There is my setup:
    My Ip-PSTN ligne is redirected directly to my local extention. (No welcome message, no AA)
    When I leave my office I activate my call forwarding *4 from my extention.
    There is the call statistics for this call
    20-09-2012 13:42:31 0 sec "45077*****" <45077*****@72.55.xxx.xxx> "Eric" 2021 call forwarded
    20-09-2012 13:42:31 0 sec "45077*****" <45077*****@72.55.xxx.xxx> "45076***** (added by VoIP Carrier Wizard)" 996 call forwarded
    I have 5 lines on my SIP Trunk
    I have no problem with my call fowarding when I use the AA or If someone take the call and transfert to me after.
  1. Call Forwarding Failure on specific FXO ports
    By dpierce in forum Troubleshooting and Problems
    Last Post: 08-23-2012, 07:54 PM
  2. Replies: 25
    Last Post: 02-11-2010, 01:06 AM
  3. Call Routing table and external forwarding
    By mountrcg in forum 'How Do I' Questions
    Last Post: 04-14-2008, 01:34 AM
  4. Call Forwarding to external number
    By t_h_048d3 in forum Suggestions and Feedback
    Last Post: 09-13-2007, 03:24 PM
