Thread: Incoming PSTN calls are Anonymous
    Feb 2012
    Melbourne, Australia
    44
    Default Incoming PSTN calls are Anonymous
    We don't have caller ID here (it costs $5 per line per month!), so all incoming PSTN calls show up on the phone display as "Anonymous". Is there any way to change that text to something else?
    Quadro 4L and Yealink T28P phones.
    Thanks, Peter
    Apr 2007
    Acton Vale, Quebec, Canada
    134
    Hi Peter, I supose you use an analogue phone connected in your Quadro and you use a PSTN line.
    In this case you need to configure when the CallerID is read durring rigning.
    Connect to Quadro with Admin login
    go to Telephony menu and clic on Line Setting
    In line setting clic on your first line "Line 1"
    In caller ID select when the ID is receive. (In north America is Standard 2 (FSK send between first and second ring)
    Rigner Type A
    Enable off-hook Caller ID
    Clic Save.
    If this doesn't work try different caller IP Standard.
    Do this for each line you have.
    Hope this helpful
    Feb 2012
    44
    Hi, Eric - thanks for your reply. I use SIP phones and PSTN lines, but the PSTN lines do not have caller ID so nothing is sent from the PSTN to the Quadro.
    The SIP phones currently display "Anonymous" for incoming PSTN calls. What I would like to do is change that message to something else - the users would like "Incoming Call" or something similar.
    Does anyone know if that is possible, and if so, how to do it?
    Thanks, Peter
  1. Incoming calls from ITSP not connecting
    By brileigh in forum 'How Do I' Questions
    Last Post: 08-22-2012, 09:32 PM
  2. Dealing with incoming calls 3 different ways
    By pjetson in forum 'How Do I' Questions
    Last Post: 05-23-2012, 04:08 AM
  3. Receptionist missing incoming calls
    By TFIDemo in forum Troubleshooting and Problems
    Last Post: 01-25-2008, 02:53 AM
  4. Routing Incoming PSTN calls to VOIP
    By mskinner in forum 'How Do I' Questions
    Last Post: 08-25-2006, 10:01 AM
