Hi Peter,
We have implemented a number of Quadros to replace similar older PABX configurations and found that the basic 2 line IP handset works well for the average user with dependance on voicemail, call hunting and queueing where applicable. Only exception is for the Reception function that may require more lines as stated by Kevin. The many feature-sets in Quadro IP PBX very often allow user to go back to a simple 1 line configuration with call hunting or fwd to extension/vmail as required.
It all boils down to what your actual business requirements are and your analysis, given the feature-sets to use, in putting forward a more superior solution. From our experience not many users can or like to 'multi-task' in attending to more that one phone conversation and utilizing the feature-sets in the Quadro, the new simplified solution works better.
Hope the above makes sense.
Regards/Sim
If you are happy with the five out going lines then you need five PSTN(FXO) or equivalent SIP trunks.
As far as the phone is concerned the very first thing you define in Epygi for an IP phone is the line appearance which is the number of simultaneous calls supported by the SIP phone. A snom M9 for instance supports 2. Have not used the Yealinks to comment. So you can hold and transfer or call out. So line appearance should not be confused with out going PSTN/SIP trunks.
Was this your question?
There are numerous alternatives open to you from IP telephones with 6 lines to two lines. By and by, most clients just need 1 line however having extra lines can be valuable relying upon the job of the client.
