Thread: FXO not installed
    Default FXO not installed
    Have a Quadro 4xi running in a non ISDN environment.
    Used a ISDN/Analogue converter to get around the problem.
    Seems to be functioning all accordingly but the error I am getting in the FXO settings is FXO not installed. Which might be normal under the conditions I have described above but not entirely sure...
    Also am not sure about the configuration for the converter please see attached two screen shots.
    For the ISDN settings in the Quadro I am using point to multi point and msn.
    Any re-assurance that the FXO settings not installed is normal would be appreciated...
    "FXO not installed" is normal because Quadro doesn't see your FXO, it is working via ISDN with your adapter. It thinks it is connected to ISDN line.
  1. Remote extension installed to a VIP client
    By sreyesro in forum 'How Do I' Questions
    Last Post: 06-29-2010, 07:17 AM
