Thread: Auto configuration on a remote extension
    Normally you cannot use the IP line auto-configuration features of the
    Quadro with a phone that is connected as a remote extension. This
    is because the auto-configuration relies on a feature of DHCP where the
    DHCP server can specify a "boot file". This "boot file" in the
    case of IP phones is actually the configuration file.
    You can get around this limitation by using a packet capture program to
    capture the DHCP traffic between a locally connected phone and the
    Quadro. You can, in that way, see what file the Quadro is
    specifying to the phone to download. After you know what file the
    phone should grab you can manually configure the remote phone to
    download the appropriate file. Usually the phone's MAC address is
    part of the file's name so you'll need to take that into account for
    the remote phone.
    At least on the SNOM 360 there is a place in the web interface to
    specify a configuration file to download. I suspect other phones
    can be similarly configured. So you setup your IP line just like you
    would if the phone were local, entering the MAC address and selecting
    the corrent phone type. This will cause the Quadro to generate
    the config file. Then configure the remote phone to use the
    correct file !!
    Of course the phone has to be able to reach your Quadro via whatever
    method it uses for downloading config files (ftp, tftp or http) so if
    the Quadro is behind a firewall or NAT device you'll have to do a bit
    more work to open the appropriate ports.
    But won't that configure the phone with IP Line credentials rather than the Remote Extension credentials?
    On the Aastra 480i at least the settings you enter via the web gui take precedence over the configuration file. So you can have the phone download the auto-config file and still use the remote extension username and password because you enter them manually using the web gui :-) I suspect this may also be the case for other Aastra phone models.
    I haven't checked the SNOM phones but this could work the same way there as well.
  1. Set up remote extensions
    By Jason@lebenton in forum Installation
    Last Post: 01-23-2009, 08:21 AM
  2. Remote Extension - SNom 360
    By netcare in forum Installation
    Last Post: 07-26-2007, 03:30 PM
  3. Remote extension unable to dial out
    By ppvote in forum Troubleshooting and Problems
    Last Post: 07-10-2007, 05:42 PM
  4. Monitor Extension in Remote Office
    By onlctrain in forum 'How Do I' Questions
    Last Post: 04-12-2007, 05:51 PM
  5. Remote Extension - WHAT OUT FOR THIS !
    By megatron in forum 'How Do I' Questions
    Last Post: 10-16-2006, 12:00 AM
