Thread: Call Routing Rules for "Call Forwarding" question
    Default Call Routing Rules for "Call Forwarding" question
    I have all my Call Routing Rules "Source Type" set to be "PBX" for security reason.
    I also have several extensions configured with "Call Forwarding" to external numbers.
    This configuration worked fine until I uprated to firmware v.5.2.47 (Q2x).
    After this upgrade, all external calls to extensions to be forwarded to external numbers are getting "temporary unavailable" error.
    If I change Call Routing Rules "Source Type" to "Any", forwarding works fine.
    (But it makes system unsecured)
    I guess new firmware is treating these calls in Call Routing Rules as external, even though they go through local extensions.
    Is this a right behavior?
    What would be a workaround?
    Alex
    What was the previous firmware version? I suppose it should have been a very old firmware...
    I suppose the the workaround here would be:
    Enter to extmanagement.cgi hidden page, edit the desired extension and enable the "Use extension settings in forwarding".
    Hope this helps.
    Vahan,
    extmanagement.cgi setting works
    Shnorhakalutyun
  1. Replies: 4
    Last Post: 06-14-2010, 08:20 AM
  2. Replies: 0
    Last Post: 06-11-2010, 12:01 AM
  3. Call Routing with "0" .
    By dolmen in forum Troubleshooting and Problems
    Last Post: 04-07-2010, 03:55 AM
  4. Diferences between new features "Listen-in", "Whisper", "Barge-in"
    By MefhigosetH in forum Suggestions and Feedback
    Last Post: 10-22-2009, 04:09 PM
  5. Call routing: SIP versus IP-PSTN "Call type"?
    By mobidutch in forum 'How Do I' Questions
    Last Post: 03-13-2008, 04:04 AM
