Thread: incoming DDI calls from Quadro4Li to legacy PBX
    Jun 2008
    St Albans, UK
    21
    Default incoming DDI calls from Quadro4Li to legacy PBX
    We have configured a Quadro 4Li to work as an ISDN gateway with a legacy PBX. All ISDN ports are configured in Network mode and incoming calls are successfully forwarded to the PBX.
    The question I have is how to pass DDI digits to the legacy PBX to enable different call routing on the PBX.
    e.g. we have 5 SIP CLIs in the range 222333100-222333104. When one of these numbers is called it should ring a particular extension on the PBX. The legacy PBX is configured to expect 6 incoming digits, so is expecting 333100, 333101 etc and these are mapped to the extensions. When we call any of the numbers the call goes to the default PBX ring group as te quadro does not appear to pass incoming DDI digits.
    "Route all incoming SIP calls to Call Routing" is ticked on Quadro and we have the following call routing entry:
    Destination Pattern Number: 22233310?, NDS=0,ISDN, trunk=any(Network).
    Is it possible to pass incoming DDI number details to the legacy PBX?
    Quadro is always passing the called number to destination. If your legacy PBX is expecting the 6 digits numbers then set NDS=3 and Quadro will remove the first 222 and send the rest to your PBX (333100, 333101...).
    Jun 2008
    St Albans, UK
    21
    Thanks for the reply, have got the incoming DDIs routing correctly now.
  1. incoming calls
    By rubendariorh in forum General Discussions
    Last Post: 11-24-2010, 12:16 PM
  2. Destination for incoming calls
    Last Post: 05-10-2010, 06:25 AM
  3. Incoming calls
    By peterd in forum 'How Do I' Questions
    Last Post: 09-16-2009, 12:41 PM
  4. incoming calls
    By mjnorris in forum Troubleshooting and Problems
    Last Post: 05-25-2009, 06:08 AM
  5. Lag time in incoming calls
    By etolentino in forum Troubleshooting and Problems
    Last Post: 01-16-2007, 02:43 PM
