Hi Everyone,
We have a Epygi Quadro 4x here running the latest firmware with firmware version control turned on.
We are using a Snom 370 we are using as a reception phone - I have set a DND button through the 'advanced' button mapping on the Epygi so that the receptionist can press the DND button when she's away from her desk to divert calls to the ring group extension. This works fine during the day - i.e. when the DND button is pressed it says "Feature Activated" and the "DND" button lights up and says on the Snom370 Screen "DND Enabled" ... and if she comes back in a short amount of time and presses the button again it says "Feature Deactivated" and the "DND" button extinguishes and the message is gone from the screen.
The problem we are having is when DND is left on overnight - each morning the receptionist has to reboot the Snom 370 else she can't turn DND off ... i.e. when she presses the DND button in the morning it speaks "Feature Deactivated" so it was still on at the Quadro... however the Snom 370 still keeps its light on and still says "DND Enabled" on the screen... no amount of button pressing disables the DND again (this causes the problem whereby calls will go to nowhere since the Epygi thinks the Snom is ringing but its actually on its own DND)
Any suggestions? is anyone using a similar scenario? Thanks in advance![]()
