Results 11 to 20 of 22
Thread: Suddenly no sip registration
    Should I buy a new router? If so, which one is especially useful for VOIP traffic?
    I use the Billion range of Routers .. they appear to work well in the several places that I have used them including my office.
    http://www.billion.com/product/product.html
    Thanks, Kevin for the recommendation. Unfortunately, the Billion Range is not available in my neck of the woods. I ordered a:
    WRVS4400N Wireless-N GB Router Cisco Small Business (Linksys Business Series)
    For me, the most important features were:
    1. VOIP support, extensive NAT support
    2. 1 Gb Switch
    3. VPN support (to connect a softphone from a distance)
    4. QoS
    It should arrive tomorrow. I will post the result ASAP.
    Default Problem still unsolved!!!!!!!!!!!!
    I received the new router today and installed it (WRVS4400N Wireless-N GB Router Cisco Small Business). All equipment in the network operate normally except for the EPYGI QUADRO 2Xi!
    The same error:
    17:39:43 Registering user 2xxxxxxx0 on server sipgate.de
    17:39:43 SipRegDlg::OnRegister # 2xxxxxxx0@sipgate.de:5060, reg:1, rr:0, id: (empty), pswd:exist, info:[OP#sipgate.de:5060][NP#0:60]
    17:39:43 SipDlg::AddServerParams # Equal outbound params in primary server params, must discard outbound params # OID: 172
    17:39:43 SipDlg: DetermineInitTarget # Call to primary server # OID: 172
    17:39:43 TargetQualifier::QualifyTargets # Try to qualify targets for dest sipgate.de # OID: 172
    17:39:43 TQAgent::UAMsgProc # Resolved addresses for host sipgate.de via default dns
    DEST: 217.10.79.9 UDP Port: 5060 TTL: unknown
    17:39:43 SipDlg: DetermineTarget # Wait for resolving destination: sipgate.de # OID: 172
    17:39:43 TargetQualifier::NatHandling # Wait response from NATAgnet # OID: 172
    17:39:43 TargetQualifier::NATAgentMsg # Got NAT response: 'fail to get NAT mapping' # ID: 5568761751686051221
    17:39:43 SipRegDlg::TQMsgProc # Got failure msg from TQAgent for destination: sipgate.de # OID: 172
    17:39:43 Registering error (Incorrect remote address), move to terminate state # OID: 172
    17:39:43 SipRegDlg::SetRegNextTimer # Next registration will be in 96 seconds # OID: 172
    In short, still "fail to get NAT mapping"
    On the router I have port 5060 forwarded to the ip address of the Quadro:
    Port Range Forwarding
    Application Epygi
    Start 5060
    End 5060
    Protocol: both
    IP Address: <ip address of Quadro>
    Enable: yes
    So why does the Quadro 2 xi fail to get NAT mapping??????
    I already spent USD 200 on a new router
  4. #14
    try to configure the NAT traversal manually, it is cheaper than $200.
    On your router forward port 5060 to IP address and port 5060 of Quadro.
    On Quadro configure the following:
    - on "Telephony -> SIP Settings" page set UDP Port: 5060
    - on "Telephony -> NAT Traversal Settings -> SIP Parameters" select Use manual NAT Traversal
    - on the same page, below, in "Mapped Host" and "Mapped Port" enter the external IP address of your router and port 5060 correspondingly
    - on "Telephony -> NAT Traversal Settings -> RTP Parameters" select Use manual NAT Traversal
    If it works, you can continue with investigation of the STUN issues.
  5. #15
    Hrant, thank you for your suggestion!
    Quote Originally Posted by hrant View Post
    in "mapped port" I need to enter a port range. When I enter 5060 until 5060, I get the following error:
    Error: RTP/RTCP port range must be less or equal to mapped RTP/RTCP port range for NAT
    So what should be the Mapped Port Range?
  6. #16
    Quote Originally Posted by keeskoets View Post
    That should have read 6000 - 6099 I think
  7. #17
    After adding the range as suggested by Kevin, I get a the following (different) message this time:
    Registering error (Can't send SIP REGISTER message), move to terminate state
    The system log is as follows:
    08:46:58 TLayer::ErrToTU # Error: Can't send message # TID: 104 # DID: 103
    08:46:58 SipRegDlg::TLErrProc # Got error from TL: Can't send message # OID: 103
    08:46:58 Registering error (Can't send SIP REGISTER message), move to terminate state # OID: 103
    08:46:58 SipRegDlg::SetRegNextTimer # Next registration will be in 96 seconds # OID: 103
    08:46:59 User registration timer fires # ID: 50
    08:46:59 Registering user 2xxxxxxx0 on server sipgate.de
    08:46:59 SipRegDlg::OnRegister # 2xxxxxxx0@sipgate.de:5060, reg:1, rr:0, id: (empty), pswd:exist, info:[OP#sipgate.de:5060][NP#0:60]
    08:46:59 SipDlg::AddServerParams # Equal outbound params in primary server params, must discard outbound params # OID: 105
    08:46:59 SipDlg:: DetermineInitTarget # Call to primary server # OID: 105
    08:46:59 TargetQualifier::QualifyTargets # Try to qualify targets for dest sipgate.de # OID: 105
    08:46:59 TQAgent::UAMsgProc # Resolved addresses for host sipgate.de via default dns
    08:46:59 SipDlg:: DetermineTarget # Wait for resolving destination: sipgate.de # OID: 105
    08:46:59 TargetQualifier::NatHandling # Wait response from NATAgnet # OID: 105
    08:46:59 TargetQualifier::NATAgentMsg # Got NAT response: 'apply NAT mapping' (82.136.73.129:5060) # ID: 5568995552525380208
    08:46:59 SipRegDlg::TQMsgProc # Got success msg from TQAgent for destination: sipgate.de # OID: 105
    08:46:59 Try to send SIP message # (02/02/2011 07:46:59:132 GMT) # UDP # 639 bytes # buff size 0 # from: 192.168.1.160:5060 # to: 217.10.79.9:5060
    REGISTER sip:sipgate.de SIP/2.0
    Via: SIP/2.0/UDP 82.136.73.129:5060;rport;branch=z9hG4bKEPSVBUS39f8 2881-7b07-4e96-8cb5-a111178c8d23
    To: "Sipgate.de -0 (added by VoIP Carrier Wizard)" <sip:2xxxxxxx0@sipgate.de>
    From: "Sipgate.de -0 (added by VoIP Carrier Wizard)" <sip:2xxxxxx0@sipgate.de>;tag=1296632572fed689f1-248a-4e99-b994-10c696f2ca18
    CSeq: 3 REGISTER
    Call-ID: 34fd267a-eea7-4d37-809c-8afb8dd00dd5...ygi-config.loc
    Contact: "Sipgate.de -0 (added by VoIP Carrier Wizard)" <sip:2xxxxxxx0@82.136.73.129:5060>;expires=3600
    User-Agent: Epygi Quadro SIP User Agent/v5.1.19 (QUADRO-2X)
    Max-Forwards: 70
    Content-Length: 0
    08:46:59 NetAgent::SendMessage # UDP send error
    08:46:59 TLayer::ErrToTU # Error: Can't send message # TID: 106 # DID: 105
    08:46:59 SipRegDlg::TLErrProc # Got error from TL: Can't send message # OID: 105
    08:46:59 Registering error (Can't send SIP REGISTER message), move to terminate state # OID: 105
    08:46:59 SipRegDlg::SetRegNextTimer # Next registration will be in 96 seconds # OID: 105
  8. #18
    Well that is interesting...
    Do u want me to take a remote look at it ? free bee
    K
  9. #19
    Thank you for your offer! I'll send you the details per PM
  10. #20
    I would be happy with advice from anybody else as well!
    I just activated one SIP account from epygi.com just to see what happens but as with all other 5 accounts, I get the following message:
    Perhaps it's easier to pick out the problem with a known SIP provider
    Here is the system file:
    22:12:53 User registration timer fires # ID: 9
    22:12:53 Registering user 79xxxx11 on server sip.epygi.com
    22:12:53 SipRegDlg::OnRegister # 7xxxxx11@sip.epygi.com:5060, reg:1, rr:0, id: (empty), pswd:exist, info:[NP#0:60]
    22:12:53 SipDlg:: DetermineInitTarget # Call to primary server # OID: 9555
    22:12:53 TargetQualifier::QualifyTargets # Try to qualify targets for dest sip.epygi.com # OID: 9555
    22:12:53 SipDlg:: DetermineTarget # Wait for resolving destination: sip.epygi.com # OID: 9555
    22:12:53 TQAgent::UAMsgProc # Resolved addresses for host sip.epygi.com via default dns
    DEST: 74.54.85.200 UDP Port: 65535 TTL: unknown
    22:12:53 TargetQualifier::NatHandling # Wait response from NATAgnet # OID: 9555
    22:12:53 TargetQualifier::NATAgentMsg # Got NAT response: 'apply NAT mapping' (82.136.73.129:5060) # ID: 5569203231374737372
    22:12:53 SipRegDlg::TQMsgProc # Got success msg from TQAgent for destination: sip.epygi.com # OID: 9555
    22:12:53 Try to send SIP message # (02/02/2011 21:12:53:880 GMT) # UDP # 525 bytes # buff size 0 # from: 192.168.1.160:5060 # to: 74.54.85.200:5060
    REGISTER sip:sip.epygi.com SIP/2.0
    Via: SIP/2.0/UDP 82.136.73.129:5060;rport;branch=z9hG4bKEPSVBUSdc2e 5c2b-de9d-4c49-afe3-70b42346a378
    To: "DECT" <sip:7xxxxx11@sip.epygi.com>
    From: "DECT" <sip:7xxxxx11@sip.epygi.com>;tag=1296632572300ca7a 7-bba0-4b06-b7c5-cda935177e4e
    CSeq: 2 REGISTER
    Call-ID: 34b89f92-c9e8-4b73-bc06-29acef6cb7bd...ygi-config.loc
    Contact: "DECT" <sip:7xxxxx11@82.136.73.129:5060>;expires=3600
    Max-Forwards: 70
    Content-Length: 0
    22:12:53 NetAgent::SendMessage # UDP send error
    22:12:53 TLayer::ErrToTU # Error: Can't send message # TID: 9556 # DID: 9555
    22:12:53 SipRegDlg::TLErrProc # Got error from TL: Can't send message # OID: 9555
    22:12:53 Registering error (Can't send SIP REGISTER message), move to terminate state # OID: 9555
    22:12:53 SipRegDlg::SetRegNextTimer # Next registration will be in 96 seconds # OID: 9555
  1. FXO and 16X lost registration
    By jorgeirisa in forum Troubleshooting and Problems
    Last Post: 11-29-2010, 09:22 AM
  2. unable to add 2nd SIP registration
    By mya in forum Troubleshooting and Problems
    Last Post: 09-17-2010, 01:00 PM
  3. Loosing Sip Registration
    By DarraghHogan in forum Troubleshooting and Problems
    Last Post: 08-06-2010, 07:11 PM
  4. SIP Registration
    By mark.daniel in forum Troubleshooting and Problems
    Last Post: 06-18-2009, 12:16 PM
  5. Phone Call ends Suddenly
    By ipgsi2x in forum Troubleshooting and Problems
    Last Post: 04-11-2007, 09:58 PM
