Thread: Quadro ISDN with asterisk pbx problems
    Default Quadro ISDN with asterisk pbx problems
    I'm connecting Quadro ISDN to a ISDN line and via SIP to an asterisk pbx
    And found two problems:
    I created two call routing rules, one for inbound calls
    call type SIP
    but i would like that when call is received into the quadro thru isdn, the ivr won't appear, instead it will pass the call directly to the pbx... any ideas about this?
    call type ISDN
    and i would like that when from the pbx, to the quadro, thru the isdn the phone that receives the call can see the isdn caller ID... I've tried an ISDN phone directly to the ISDN line and when calling it presents the caller ID so I believe is not problem of the pstn service. I believe that this has something to do with the Quadro.
    Any ideas about this two issues?
    I could managed to solve this by myself.
    Problem was I did not config the MSN data in the ISDN trunks configuration tab.
    I solved with this, both issues at once.
  1. Quadro Voicemail to Email problems
    By KejiO in forum Troubleshooting and Problems
    Last Post: 10-24-2011, 04:31 PM
  2. Quadro 2x PBX and Quadro ISDN Gateway
    By NuV1 in forum Troubleshooting and Problems
    Last Post: 05-06-2009, 12:24 PM
  3. Asterisk/Trixbox and Epygi isdn gateway
    By truevoice in forum Troubleshooting and Problems
    Last Post: 04-10-2009, 12:22 PM
  4. Quadro 16xi problems - ISDN trunks, system hangs.
    Last Post: 04-17-2008, 07:30 AM
  5. asterisk as client to quadro
    By tomcameron in forum 'How Do I' Questions
    Last Post: 11-02-2007, 03:47 PM
