Results 1 to 8 of 8
Thread: Unconditional Call Forward
    Default Unconditional Call Forward
    Hi
    I have a site where the unconditional call forward when activated via the *4 feature code gets activated OK but when you call the number it doesn't get forwarded to the assigned number in the Supplimentary Services/Caller ID Based Services. Its still going to the phones in the office. Checked the Unconditional call forward settings and the number is there and toggle from handset is ticked.
    Please help
    Thank you
    Kelly244
    Quadro2X 5.1.31
    Enable Service Enable/Disable Add Edit Delete Select all Inverse Selection
    State Forward to
    Enabled Auto-9021763037
    Send Notification Via SMS Mobile Number
    Send E-mail E-mail Address
    Toggle from Handset
    Quote Originally Posted by kellymartin244 View Post
    Hi
    Please help
    Thank you
    Kelly244
    Quadro2X 5.1.31
    State Forward to
    Toggle from Handset
    In call routing is 9021763037 an emtry that does not have the filter rule applied if not make an entry and allow the rule.
    Thanks Kevin. Will try that and see how it goes.
    All,
    Routing Rules with PBX filter will work when used in a Forwarding set on the extension. It works starting from 5.1 FW version, so this couldn't be the reason for this issue
    Ashot
    kelly,
    In your snapshot above isn't shown what specific address the forwarding is configured for. So my question is - when you calling the extension number and it doesn't get forwarded to the assigned number, are you sure you are calling from the specified address?
    Ashot
    I didnt see this in the notes for the firmware, can you elaborate please.
    Hi Kevin,
    I am surprised that there are Quadro features that you are not aware of.
    Please take a look to the RNs Quadro2x/4x/16x 5.2.12 under new features for the 5.1.17 release. This feature shortly described there as follows: "Easier for extensions to forward their calls to external numbers without compromising the security of Call Routing entries that have the PBX filtering option enabled."
    Actually this feature allows the Routing Rules with PBX filter to work when used in a Forwarding set on the extension. No additional configuration needed.
    Ashot
    It wasnt the feature that I wasnt aware of, it was the changes made so you didnt have to remove the filtering for the forwarding to work.
    In the past I would use a pincode for the route and have that as an entry within the system to allow dialling out of the system without the filtering applied.
    I actually looked through the file and either skimmed over the entry that you posted or wasnt looking in the right place.
    Thanx for the heads up...
  1. How to do unconditional call forwarding?
    By MEDIAPCSYSTEM in forum 'How Do I' Questions
    Last Post: 03-10-2009, 02:55 PM
  2. Call Drops on Unconditional Call Forwarding
    By ASL-Support in forum Troubleshooting and Problems
    Last Post: 03-09-2009, 04:51 AM
  3. forward call and pickup
    Last Post: 11-16-2008, 04:25 PM
  4. Call statistics not showing after call forward latest firmware.
    Last Post: 06-30-2008, 11:59 AM
  5. Call Forward
    By blackbox in forum 'How Do I' Questions
    Last Post: 06-25-2007, 06:17 AM
