Thread: Quadro and X-lite 3.0 - one way audio
    I'm having problems with x-lite version 3 build 34025. I've tried to follow the example pdf docs X-LiteConfig-MedRes.pdf and Xlite-with-EPYGI-E2.pdf but these are for much older versions of x-lite.
    I'm connecting to the Lan side of the quadro. Registration as an extension is fine, and I can make outbound calls.
    However, if some connect via the PSTN (FXO port), I can hear them but they can't hear me. I have confirmed that the packets are reaching the quadro in the 80xx range - it seems the x-lite is not sending the audio packets to the quadro.
    The set up I have is an ADSL modem on a fixed IP address, with a DMZ pointing to the quadro.
    I don't believe that pin holes are neccessary, as the quadro should be recieving and sending the call as it is configured as the proxy address in the x-lite. ( I have tried this too with no avail!)
    Help!
    Rhys
    Solved - by Ski Bum from CounterPart support.
    These can be
    corrected as follows:
    STUN:
    Please try specifying
    stun.counterpath.net for the STUN server.
    Codec’s:
    Dial ***7469
    (SEND)
    This will bring up
    the advanced settings window
    Filter for
    honor
    Double click on the
    honor entry and change the value to 1
    Save and
    restart.
  1. HUD Lite integration into Quadro
    By ayenacom in forum Tips and Tricks
    Last Post: 11-11-2009, 02:48 AM
  2. Using Quadro audio files w/ VXML
    By threebit in forum VXML Scripting on Quadro
    Last Post: 10-27-2009, 03:14 AM
  3. How do I configure X-Lite Softphone
    By ciasulamericana in forum 'How Do I' Questions
    Last Post: 03-12-2008, 03:45 AM
  4. x-lite weirdness
    By lansmart in forum 'How Do I' Questions
    Last Post: 10-02-2007, 05:24 AM
  5. Quadro, X-lite - does presence work?
    By rhysw in forum 'How Do I' Questions
    Last Post: 02-13-2007, 10:14 PM
