Thread: How to edit extension in call routing table without tick box
    Question How to edit extension in call routing table without tick box
    I have an Epygi 2xi and just signed up with a cheap calling service. To activate this service, I need to dial a 5 digit code before dialing out.
    My ISDN lines are set up under prefix 0 and 5. So when dialing out on 0 for example, I would like the Epygi to add "10787" for every outgoing call.
    I managed to do this for the extension 5, because I could edit the variable "PREFIX" in the call routing table. I added 10787 and it works.
    How do I do this for extension 0 where there is no tick box to edit the extension??
    The "0" is default (automatically created) routing rule, that is why there is no checkbox for it. So you have to delete and manually add it again. How to delete:
    Run the "System Configuration Wizard", go to the "Emergency Codes and PSTN Access Code Settings", set the "PSTN Access Code" to blank and finalize the wizard.
    Ashot
  1. Printing full extensions table and call routing table
    By Internet in forum 'How Do I' Questions
    Last Post: 03-24-2010, 02:43 PM
  2. Call Routing Table CRT
    By cornepiek in forum Troubleshooting and Problems
    Last Post: 11-14-2008, 06:57 AM
  3. Call Routing Table limits
    By lambsons in forum 'How Do I' Questions
    Last Post: 06-27-2008, 10:37 AM
  4. Call Routing table and external forwarding
    By mountrcg in forum 'How Do I' Questions
    Last Post: 04-14-2008, 02:34 AM
  5. IVR to call routing table
    By andy.collins in forum VXML Scripting on Quadro
    Last Post: 10-02-2007, 08:24 AM
