Thread: Fault and Lan Lights flash at same time
    Default Fault and Lan Lights flash at same time
    Here is the symptom - fault light comes on. The busy, fault and LAN lights flash at the same time, and then the Busy and Info light come on and the process repeats.
    Does this require a factory reset, or is this indicative of a hardware failure?
    Quote Originally Posted by thodgen View Post
    Which system ? is it a 4x or larger ?
    If so, does it have a memory stick / flash card in it ? if so remove it after you power the device down and then restart, does that fix it now ?
    If so, run the usb stick / flash card up on a PC and see if it is readable ( you will need a Linux reader - from memory )
    If it isnt readable - its a dodgy part and needs replacement.
  1. Time to time long beep signals during conversation
    By riskdata in forum Troubleshooting and Problems
    Last Post: 10-03-2011, 01:30 AM
  2. utilisation touche flash sur une fxo
    By roussel in forum Français
    Last Post: 11-16-2009, 09:22 AM
  3. Power failure- "FAULT" LED shows up
    By sgaddam in forum Troubleshooting and Problems
    Last Post: 10-21-2009, 02:17 PM
  4. SIP Flash for Polycom IP phones
    By primorisgroup in forum 'How Do I' Questions
    Last Post: 05-22-2009, 08:55 AM
  5. USB Flash drive - behaviour
    By KSComs in forum Troubleshooting and Problems
    Last Post: 10-14-2008, 09:54 AM
