Hi Hrant,
Attachment now attached.
Camrivox Flexor CTI, will create a Journal Entry in Outlook to record the call being made or received (with the number in the subject), and also gives the option to open a task form, or another form from a private or public folder. This allows our customer to record the call details and then save it as an outlook item (Or send it on to a colleague for action). We have found flexor to be unreliable (the software not the Outlook integration) and would like the hotcall addin to do the same. If hot call would have these option it would be excellent.
http://www.camrivox.com/products/flexor-connect-snom/
