Thread: VXML script not working,
    Hi, we want to choose an extension before the prompt ends but it doesn't read the digits keyed in and starts back again.
    Somehow when it jumps to the field1 or field3 segment it does not read the digits correctly.
    Any idea?
    <?xml version="1.0" encoding="UTF-8"?>
    <vxml version="2.0">
    <noinput count="1">
    <assign name="field1" expr="'61'"/>
    <goto nextitem="field2" />
    </noinput>
    <form id="mainform">
    <object name="dtfield" classid="datetime">
    <filled>
    <if cond="datetime_wday == '1'">
    <prompt bargein="true"> <audio src="welcome.wav" /> </prompt>
    <goto nextitem="field3"/>
    </if>
    <if cond="datetime_wday == '7'">
    </if>
    <if cond="datetime_hour &amp;gt; '7'">
    <if cond="datetime_hour &amp;lt; '17'">
    <goto nextitem="field1" />
    <elseif cond="datetime_hour == '17'"/>
    <if cond="datetime_min &amp;lt; '31'">
    <elseif cond="datetime_min &amp;gt; '30'" />
    </if>
    <elseif cond="datetime_hour == '7'"/>
    <goto nextitem="field3" />
    <goto nextitem="field1"/>
    </if>
    <elseif cond="datetime_hour gt; '17'"/>
    </if>
    <else/>
    </if>
    </filled>
    </object>
    <field name="field1" type="digits?length=1" modal="false">
    <link dtmf="#" next="#dirspell"/>
    <prompt bargein="true" timeout="5s">
    <audio src="recurring.wav" />
    </prompt>
    <option dtmf="1" value="44" />
    <option dtmf="2" value="30" />
    <option dtmf="0" value="61"/>
    <filled>
    <goto nextitem="field2"/>
    </filled>
    </field>
    <object name="field2" classid="connect">
    <param name="extension" expr="field1"/>
    <filled>
    <prompt> <audio src="timeover.wav" /> </prompt>
    <exit/>
    </filled>
    <nomatch>
    </nomatch>
    </object>
    <field name="field3" type="digits?length=1" modal="false">
    <prompt timeout="5s">
    <audio src="closed.wav" />
    </prompt>
    <filled>
    <goto nextitem="field4"/>
    </filled>
    </field>
    <object name="field4" classid="connect">
    <param name="extension" expr="field3"/>
    <filled>
    <noinput count="1">
    </noinput>
    </filled>
    <nomatch>
    </nomatch>
    </object>
    </form>
    <var name="varExtension"/>
    <var name="varFilename"/>
    <var name="varRoll" expr="'true'"/>
    <form id="dirspell">
    <link dtmf="*" next="#mainform"/>
    <object name="field5" classid="directory">
    <param name="roll" expr="varRoll"/>
    <prompt> <audio src="pubdirspell.wav" /> </prompt>
    <nomatch>
    <prompt> <audio src="nomatch.wav" /> </prompt>
    <reprompt/>
    </nomatch>
    <filled>
    <assign name="varExtension" expr="_extension" />
    <assign name="varFilename" expr="_filename" />
    <assign name="varRoll" expr="'false'" />
    <goto next="#diraccept"/>
    </filled>
    </object>
    </form>
    <!-- accept menu, plays file attached to spelled extension -->
    <!-- and offers three choices to input -->
    <menu id="diraccept">
    <prompt> <audio expr="varFilename" /> </prompt>
    <prompt> <audio src="pubdiraccept.wav" /> </prompt>
    <choice dtmf="1" next="#dirroll"/>
    <choice dtmf="*" next="#dirspell"/>
    <choice dtmf="#" next="#dirmainform"/>
    </menu>
    <!-- roll form, sets varRoll to true to perform roll over the spelled entries -->
    <form id="dirroll">
    <block>
    <assign name="varRoll" expr="'true'" />
    <goto next="#dirspell"/>
    </block>
    </form>
    <!-- main form, dials to already spelled and accepted extension -->
    <form id="dirmainform">
    <param name="extension" expr="varExtension"/>
    <filled>
    <exit/>
    </filled>
    <nomatch>
    </nomatch>
    </object>
    </form>
    </vxml>
    I'll try to interpret your script.
    At the first, script invokes "datetime" object and according to current time jumps to "field1" or "field3".
    Then interpreter waits for input.
    This means that digit length is 1 in another words no more than one digit is acceptable here.
    I believe it should be
    <field name="field1" type="digits?length=2" modal="false">
    However you still can define options with one digit
    Hope it'll help.
    ________
    M5
    ________
    Vaporizers
  1. Using Quadro audio files w/ VXML
    By threebit in forum VXML Scripting on Quadro
    Last Post: 10-27-2009, 03:14 AM
  2. VXML Help
    By stakano in forum 'How Do I' Questions
    Last Post: 08-06-2007, 06:26 PM
  3. XML script HELP
    By alfredp in forum VXML Scripting on Quadro
    Last Post: 03-05-2007, 07:12 AM
  4. Out of Hours Script
    By ivscorp in forum Troubleshooting and Problems
    Last Post: 03-04-2007, 12:45 PM
  5. CID not working
    By alraiky in forum 'How Do I' Questions
    Last Post: 09-23-2006, 06:16 AM
