I have been searching this forum for a solution to my problem. I need help for my remote extensions working properly on my Epygi Quadro 4x.
The problem I'm facing is that my Remote Extensions (Snom 300, Snom 320) are not registring properly. The registration keeps dropping after a certain time. I have assigned different static IP addresses to my remote extensions phones (all my remote extensions are on the same remote site), but some how Quadro is not getting the correct IP address. IP Line Registration Status shows the same IP address of all the remote extensions.
Could you please advise how to setup these remote extensions. I have read plenty of posts here, and have tried different solutions suggested here but none seems to be working in my case.
I would appreciate if you can advise in simple steps how to register the remote extensions. Please let me know if you need any information regarding the network settings or my extensions settings.
I would really appreciate your help.
Sajjad
