Thread: Default Attendant routing fails
    Default Default Attendant routing fails
    Hi all
    I configured a new Q6L last week (current software release), set up 1 analogue trunk and 2 user extensions (SNOM300).
    When I made test calls, i can call internally between extensions, I can make calls out, and I can receive calls through the analgoue trunk. This is what happens when I call in:
    - Attendant answers (default greeting: Welcome to attendant, if you know the extension dial it now) -> I can dial either of the two configured extensions, call is presented to the correct extension
    - If I do NOT dial an extension (the call should go to a pick up group of which both extensions are part of): Attendant first prompts to dial the extension, then after one pass it prompts to search by name, followed by #. If I dial the opt out, I get prompted for user name and password, if I do nothing, call tries to route, but disconnects.
    I have not installed the system on site yet, as I want to resolve this first.
    I am a bit lost here, I compared my config with a known working system, and can't see any difference.
    Where do I start looking?
    Thanks and regards
    The system needed to be changed to PBX in the KSE configuration hidden page. That problem solved.
  1. Call forwarding fails
    By Franz in forum Troubleshooting and Problems
    Last Post: 12-18-2012, 11:57 PM
  2. FXO port fails diagnostic test – PSTN line is good
    By netpcs in forum Troubleshooting and Problems
    Last Post: 04-02-2010, 11:03 AM
  3. FXO Diagnostics fails...
    By dhebert in forum Troubleshooting and Problems
    Last Post: 04-30-2009, 12:10 PM
  4. SMTP test mail fails
    By mobidutch in forum Troubleshooting and Problems
    Last Post: 03-17-2008, 09:09 AM
  5. QuadroE1 fails to register extension
    By damovo in forum Troubleshooting and Problems
    Last Post: 02-15-2007, 06:05 AM
