Thread: ST2030 Thomson Firmware compatible for Epygi 2x
    Default ST2030 Thomson Firmware compatible for Epygi 2x
    I've Thomson ST2030 with v1.66 (or new), but when I do auto-provissioning from Epygi i receaved "provisiong Error! Corrupted Config Still using v1.66" What I do??
    This is a log from ST2030
    Autoprovision Process start
    Begin General file download...
    General file: ST2030S_001F9F16BA19.inf download successfully!
    Begin Firmware download...
    Error: Wrong firmware configuration!
    Begin DSP download...
    Ignore dsp update - No dsp configuration included!
    Begin Boot Code download...
    Ignore boot code update - No boot code configuration included!
    Begin Melody download...
    Ignore melody update - No melody configuration included!
    Begin System Melody download...
    Begin Call waiting tone download...
    Begin Tone Table download...
    Ignore tone table - No tone table included!
    Begin Language Table download...
    Ignore language table - No language table included!
    Begin Telephone Config download...
    TelConfig: TelConf2030S.txt download successfully!
    Begin Common Config download...
    CommonConfig: ST2030S_common.txt download successfully!
    Begin Mac config download...
    MacConfig: ST2030S_001F9F16BA19.txt download successfully!
    Serial number is not the same!
    Begin upgrading config file...
    Check config file syntax
    Error: Config file format error!
    Reboot.....
    Telephone config filename is the same!
    Autoprovision Process End
    Manual update springs to mind.... have you considered that ?
    Just in case its a compatability problem with your thompson...
    OK manual update but when I auto-provisiong from Epygi all data lost...
    There might be backward compatibility issues with configuration files used by Thomson phones. Depending on the Quadro and Thomson fw. Which image versions are you using?
    For st2030 v.1.57 or newer, for epygi 5.1.39 dsp 5.1.15
  1. List of Compatible phones with Epygi
    By cembick123 in forum Hardware Interoperability
    Last Post: 01-26-2010, 02:44 PM
  2. Firmware bug for 2XI and FXO Gateway current firmware
    By KSComs in forum Troubleshooting and Problems
    Last Post: 06-26-2009, 08:59 AM
  3. Quadro 2xi & Thomson ST2030
    By acsinove in forum Troubleshooting and Problems
    Last Post: 05-27-2009, 04:08 PM
  4. Firmware V 5.1
    By KSComs in forum Announcements
    Last Post: 03-20-2009, 06:34 PM
  5. Softphone compatible with Windows Mobile
    By quadro2net in forum General Discussions
    Last Post: 12-02-2008, 07:35 PM
