Thread: Call drops whenever it is a fax
    Default Call drops whenever it is a fax
    Strange issue:
    Provider:- Simple Signal
    Issue:
    Whenever there is fax coming in, the call drops within a few seconds. If you call the same number and talk or leave a message or even put an analog phone and answer on the extension, the call has not problem.
    The minute you send fax tones, the call drops - please help.
    See logs below:
    INVITE sip:2147052058@24.155.238.18:5060 SIP/2.0
    Via: SIP/2.0/UDP 208.77.200.13:5060;branch=z9hG4bK1opde1009gr01bk7g 641.1
    From: <sip:208.77.200.13>;tag=SD8kghd01-209075441-1271026844322-
    To: "demo trunk"<sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>
    Call-ID: SD8kghd01-ad4951b2c6e0e5d15c3ee6ec414d8ddd-vrvvfv3
    CSeq: 932004178 INVITE
    Contact: <sip:208.77.200.13:5060;transport=udp>
    Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOT IFY
    Accept: multipart/mixed,application/media_control+xml,application/sdp
    Max-Forwards: 9
    Content-Type: application/sdp
    Content-Length: 172
    v=0
    o=BroadWorks 119788678 1 IN IP4 208.77.200.13
    s=-
    c=IN IP4 208.77.200.13
    t=0 0
    m=audio 56092 RTP/AVP 0 18 101
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-15
    18:00:43 Try to send SIP message # (11/04/2010 23:00:43:554 GMT) # UDP # 343 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 100 Trying
    To: "demo trunk" <sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>
    Content-Length: 0
    18:00:43 UA --> CM # MakeCall # from: (empty)@208.77.200.13:, to: 2147052058, child: 4692875690, media exist, GUID: (empty) # ContactInfo: 208.77.200.13 # SID: 5459018723023684616
    18:00:43 CM --> UA # OnUpdateUserInfo # OID: 172637 # SID: 5459018723023684616
    18:00:43 CM --> UA # OnRinging # Media not exist # OID: 172637 # SID: 5459018723023684616
    18:00:43 Try to send SIP message # (11/04/2010 23:00:43:640 GMT) # UDP # 517 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 180 Ringing
    To: "demo trunk" <sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>;tag=12573568491c2e9106-6b3b-4084-b3cc-9095dbdde04b
    Contact: "demo trunk" <sip:2147052058@24.155.238.18:5060>
    Server: Epygi Quadro SIP User Agent/v5.1.6 (QUADRO-FXO-IPPBX)
    Content-Length: 0
    18:00:44 CM --> UA # OnAccept # Media exist #OID: 172637 # SID: 5459018723023684616
    18:00:44 Try to send SIP message # (11/04/2010 23:00:44:667 GMT) # UDP # 893 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 200 OK
    Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, UPDATE
    Supported: replaces, norefersub
    Content-Length: 224
    v=0
    o=- 497 493 IN IP4 24.155.238.18
    s=-
    c=IN IP4 24.155.238.18
    t=0 0
    m=audio 6064 RTP/AVP 0 18 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:18 G729/8000
    a=fmtp:18 annexb=no
    a=fmtp:101 0-15
    18:00:44 Receive SIP message # (11/04/2010 23:00:44:801 GMT) # UDP # 484 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    ACK sip:2147052058@24.155.238.18:5060 SIP/2.0
    Via: SIP/2.0/UDP 208.77.200.13:5060;branch=z9hG4bK1opdu100d8n0eakue 301.1
    CSeq: 932004178 ACK
    Max-Forwards: 9
    Content-Length: 0
    18:00:44 UA --> CM # Done # media not exist # SID: 5459018723023684616
    18:00:53 CM --> UA # OnChangeMedia # Media exist # OID: 172637 # SID: 5459018723023684616
    18:00:53 Try to send SIP message # (11/04/2010 23:00:53:683 GMT) # UDP # 837 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    INVITE sip:208.77.200.13:5060;transport=UDP SIP/2.0
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUS487f c3c4-893c-4708-9ce6-f6324cbb0e5d
    To: <sip:208.77.200.13>;tag=SD8kghd01-209075441-1271026844322-
    From: "demo trunk" <sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>;tag=12573568491c2e9106-6b3b-4084-b3cc-9095dbdde04b
    CSeq: 671 INVITE
    User-Agent: Epygi Quadro SIP User Agent/v5.1.6 (QUADRO-FXO-IPPBX)
    Max-Forwards: 70
    Content-Length: 212
    v=0
    o=- 497 494 IN IP4 24.155.238.18
    s=-
    t=0 0
    m=image 6066 udptl t38
    a=T38FaxVersion:0
    a=T38MaxBitRate:14400
    a=T38FaxRateManagement:transferredTCF
    a=T38FaxUdpEC:t38UDPRedundancy
    18:00:53 Receive SIP message # (11/04/2010 23:00:53:747 GMT) # UDP # 541 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    SIP/2.0 401 Unauthorized
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUS487fc3c4-893c-4708-9ce6-f6324cbb0e5d;rport=5060
    CSeq: 671 INVITE
    WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXg7wgklmnT460iltBW",al gorithm=MD5,realm="elinkdashboard.com"
    Content-Length: 0
    18:00:53 Try to send SIP message # (11/04/2010 23:00:53:753 GMT) # UDP # 527 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    ACK sip:208.77.200.13:5060;transport=UDP SIP/2.0
    CSeq: 671 ACK
    Max-Forwards: 70
    Content-Length: 0
    18:00:53 Got 401 response, try to authenticate message # OID: 172637 # SID: 5459018723023684616
    18:00:53 Try to send SIP message # (11/04/2010 23:00:53:774 GMT) # UDP # 1086 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUSe500 906c-58e0-46c0-80d3-28e5a998264e
    CSeq: 672 INVITE
    Max-Forwards: 70
    Authorization: DIGEST realm="elinkdashboard.com",nonce="BroadWorksXg7wgk lmnT460iltBW",username="2147052058",uri="sip:208.7 7.200.13:5060;transport=UDP",algorithm=MD5,qop=aut h,cnonce="1593f31c",nc=00000001,response="e30b732a 3b87dc29cd59c2994eed5b92"
    Content-Length: 212
    v=0
    s=-
    t=0 0
    a=T38FaxVersion:0
    18:00:53 Receive SIP message # (11/04/2010 23:00:53:839 GMT) # UDP # 541 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUSe500906c-58e0-46c0-80d3-28e5a998264e;rport=5060
    CSeq: 672 INVITE
    WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXg7wgklp6T7dmxouBW",al gorithm=MD5,realm="elinkdashboard.com"
    Content-Length: 0
    18:00:53 UA --> CM # CloseCall # reason: Authorization # SID: 5459018723023684616
    18:00:53 CM --> UA # OnCloseCall # OID: 172637 # SID: 5459018723023684616
    18:00:53 Try to send SIP message # (11/04/2010 23:00:53:888 GMT) # UDP # 527 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    CSeq: 672 ACK
    Max-Forwards: 70
    Content-Length: 0
    18:00:53 Try to send SIP message # (11/04/2010 23:00:53:908 GMT) # UDP # 527 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    BYE sip:208.77.200.13:5060;transport=UDP SIP/2.0
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUS3d79 b1a6-b47f-4e3e-b42b-d583ba1d34ae
    CSeq: 673 BYE
    Max-Forwards: 70
    Content-Length: 0
    18:00:53 Receive SIP message # (11/04/2010 23:00:53:968 GMT) # UDP # 413 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUS3d79b1a6-b47f-4e3e-b42b-d583ba1d34ae;rport=5060
    CSeq: 673 BYE
    Content-Length: 0
    18:04:12 Receive SIP message # (11/04/2010 23:04:12:182 GMT) # UDP # 777 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 208.77.200.13:5060;branch=z9hG4bK1opdu93038dh3cg8k 2s1.1
    From: <sip:208.77.200.13>;tag=SDnbbr901-1259050696-1271027052952-
    Call-ID: SDnbbr901-19701eb7ca9b2a51467c7addae62ab03-vrvvfv3
    CSeq: 932108493 INVITE
    Max-Forwards: 9
    Content-Length: 172
    v=0
    o=BroadWorks 119792623 1 IN IP4 208.77.200.13
    s=-
    t=0 0
    m=audio 49590 RTP/AVP 0 18 101
    a=fmtp:101 0-15
    18:04:12 Try to send SIP message # (11/04/2010 23:04:12:186 GMT) # UDP # 344 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 100 Trying
    Content-Length: 0
    18:04:12 UA --> CM # MakeCall # from: (empty)@208.77.200.13:, to: 2147052058, child: 4692875690, media exist, GUID: (empty) # ContactInfo: 208.77.200.13 # SID: 5459019620671482444
    18:04:12 CM --> UA # OnUpdateUserInfo # OID: 172642 # SID: 5459019620671482444
    18:04:12 CM --> UA # OnRinging # Media not exist # OID: 172642 # SID: 5459019620671482444
    18:04:12 Try to send SIP message # (11/04/2010 23:04:12:287 GMT) # UDP # 518 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 180 Ringing
    To: "demo trunk" <sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>;tag=12573568490575bf2f-acab-4bc9-afc3-20094997c03b
    Content-Length: 0
    18:04:13 CM --> UA # OnAccept # Media exist #OID: 172642 # SID: 5459019620671482444
    18:04:13 Try to send SIP message # (11/04/2010 23:04:13:285 GMT) # UDP # 894 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 200 OK
    Content-Length: 224
    v=0
    o=- 445 458 IN IP4 24.155.238.18
    s=-
    t=0 0
    m=audio 6068 RTP/AVP 0 18 101
    a=fmtp:18 annexb=no
    a=fmtp:101 0-15
    18:04:13 Receive SIP message # (11/04/2010 23:04:13:399 GMT) # UDP # 485 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 208.77.200.13:5060;branch=z9hG4bK1opdea307obgtboal 3c0.1
    CSeq: 932108493 ACK
    Max-Forwards: 9
    Content-Length: 0
    18:04:13 UA --> CM # Done # media not exist # SID: 5459019620671482444
    18:04:22 CM --> UA # OnChangeMedia # Media exist # OID: 172642 # SID: 5459019620671482444
    18:04:22 Try to send SIP message # (11/04/2010 23:04:22:361 GMT) # UDP # 838 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUS82b0 3e11-36c2-44bb-911f-f77d618060c2
    To: <sip:208.77.200.13>;tag=SDnbbr901-1259050696-1271027052952-
    From: "demo trunk" <sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>;tag=12573568490575bf2f-acab-4bc9-afc3-20094997c03b
    CSeq: 485 INVITE
    Max-Forwards: 70
    Content-Length: 212
    v=0
    o=- 445 459 IN IP4 24.155.238.18
    s=-
    t=0 0
    m=image 6070 udptl t38
    a=T38FaxVersion:0
    18:04:22 Receive SIP message # (11/04/2010 23:04:22:425 GMT) # UDP # 542 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUS82b03e11-36c2-44bb-911f-f77d618060c2;rport=5060
    CSeq: 485 INVITE
    WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXg7wgp2ncTtq7c6oBW",al gorithm=MD5,realm="elinkdashboard.com"
    Content-Length: 0
    18:04:22 Try to send SIP message # (11/04/2010 23:04:22:431 GMT) # UDP # 528 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    CSeq: 485 ACK
    Max-Forwards: 70
    Content-Length: 0
    18:04:22 Got 401 response, try to authenticate message # OID: 172642 # SID: 5459019620671482444
    18:04:22 Try to send SIP message # (11/04/2010 23:04:22:453 GMT) # UDP # 1087 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUSc300 9f77-7d31-4239-a461-cb7aa6c20e29
    CSeq: 486 INVITE
    Max-Forwards: 70
    Authorization: DIGEST realm="elinkdashboard.com",nonce="BroadWorksXg7wgp 2ncTtq7c6oBW",username="2147052058",uri="sip:208.7 7.200.13:5060;transport=UDP",algorithm=MD5,qop=aut h,cnonce="1593f31c",nc=00000001,response="80bc81ec a4455458420eb1c190b1f4b0"
    Content-Length: 212
    v=0
    s=-
    t=0 0
    a=T38FaxVersion:0
    18:04:22 Receive SIP message # (11/04/2010 23:04:22:518 GMT) # UDP # 542 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUSc3009f77-7d31-4239-a461-cb7aa6c20e29;rport=5060
    CSeq: 486 INVITE
    WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXg7wgp2pwTnnzv4rBW",al gorithm=MD5,realm="elinkdashboard.com"
    Content-Length: 0
    18:04:22 UA --> CM # CloseCall # reason: Authorization # SID: 5459019620671482444
    18:04:22 CM --> UA # OnCloseCall # OID: 172642 # SID: 5459019620671482444
    18:04:22 Try to send SIP message # (11/04/2010 23:04:22:608 GMT) # UDP # 528 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    CSeq: 486 ACK
    Max-Forwards: 70
    Content-Length: 0
    18:04:22 Try to send SIP message # (11/04/2010 23:04:22:623 GMT) # UDP # 528 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUS340f 0c81-864f-477f-8745-89e3bf157560
    CSeq: 487 BYE
    Max-Forwards: 70
    Content-Length: 0
    18:04:22 Receive SIP message # (11/04/2010 23:04:22:682 GMT) # UDP # 414 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUS340f0c81-864f-477f-8745-89e3bf157560;rport=5060
    CSeq: 487 BYE
    Content-Length: 0
    18:08:17 Receive SIP message # (11/04/2010 23:08:17:026 GMT) # UDP # 777 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 208.77.200.13:5060;branch=z9hG4bK1opfe4301880hbgie 6g1.1
    From: <sip:208.77.200.13>;tag=SDp4a1c01-1359105624-1271027297791-
    Call-ID: SDp4a1c01-5405a65f997df6a31fdc26124aff048e-vrvvfv3
    CSeq: 932230912 INVITE
    Max-Forwards: 9
    Content-Length: 172
    v=0
    o=BroadWorks 119797353 1 IN IP4 208.77.200.13
    s=-
    t=0 0
    m=audio 51118 RTP/AVP 0 18 101
    a=fmtp:101 0-15
    18:08:17 Try to send SIP message # (11/04/2010 23:08:17:031 GMT) # UDP # 344 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 100 Trying
    Content-Length: 0
    18:08:17 UA --> CM # MakeCall # from: (empty)@208.77.200.13:, to: 2147052058, child: 4692875690, media exist, GUID: (empty) # ContactInfo: 208.77.200.13 # SID: 5459020672938313812
    18:08:17 CM --> UA # OnUpdateUserInfo # OID: 172650 # SID: 5459020672938313812
    18:08:17 CM --> UA # OnRinging # Media not exist # OID: 172650 # SID: 5459020672938313812
    18:08:17 Try to send SIP message # (11/04/2010 23:08:17:118 GMT) # UDP # 518 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 180 Ringing
    To: "demo trunk" <sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>;tag=12573568493c6e0da6-3cf0-45e3-8682-33d0cd0f73de
    Content-Length: 0
    18:08:18 CM --> UA # OnAccept # Media exist #OID: 172650 # SID: 5459020672938313812
    18:08:18 Try to send SIP message # (11/04/2010 23:08:18:143 GMT) # UDP # 894 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    SIP/2.0 200 OK
    Content-Length: 224
    v=0
    o=- 988 253 IN IP4 24.155.238.18
    s=-
    t=0 0
    m=audio 6072 RTP/AVP 0 18 101
    a=fmtp:18 annexb=no
    a=fmtp:101 0-15
    18:08:18 Receive SIP message # (11/04/2010 23:08:18:284 GMT) # UDP # 485 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 208.77.200.13:5060;branch=z9hG4bK1opfu4305gogub0j7 780.1
    CSeq: 932230912 ACK
    Max-Forwards: 9
    Content-Length: 0
    18:08:18 UA --> CM # Done # media not exist # SID: 5459020672938313812
    18:08:23 CM --> UA # OnChangeMedia # Media exist # OID: 172650 # SID: 5459020672938313812
    18:08:23 Try to send SIP message # (11/04/2010 23:08:23:632 GMT) # UDP # 838 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUS61c5 d056-22db-44d2-a4a6-07cbfa17d8d2
    To: <sip:208.77.200.13>;tag=SDp4a1c01-1359105624-1271027297791-
    From: "demo trunk" <sip:4692875690@elinkdashboard.com;ssig=ACC-banjcfdj1lb94>;tag=12573568493c6e0da6-3cf0-45e3-8682-33d0cd0f73de
    CSeq: 876 INVITE
    Max-Forwards: 70
    Content-Length: 212
    v=0
    o=- 988 254 IN IP4 24.155.238.18
    s=-
    t=0 0
    m=image 6074 udptl t38
    a=T38FaxVersion:0
    18:08:23 Receive SIP message # (11/04/2010 23:08:23:696 GMT) # UDP # 542 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUS61c5d056-22db-44d2-a4a6-07cbfa17d8d2;rport=5060
    CSeq: 876 INVITE
    WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXg7wgu8teTdg0oyzBW",al gorithm=MD5,realm="elinkdashboard.com"
    Content-Length: 0
    18:08:23 Got 401 response, try to authenticate message # OID: 172650 # SID: 5459020672938313812
    18:08:23 Try to send SIP message # (11/04/2010 23:08:23:710 GMT) # UDP # 528 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    CSeq: 876 ACK
    Max-Forwards: 70
    Content-Length: 0
    18:08:23 Try to send SIP message # (11/04/2010 23:08:23:721 GMT) # UDP # 1087 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUS979d 9887-4cf9-4faf-9fc3-a14cb874de5b
    CSeq: 877 INVITE
    Max-Forwards: 70
    Authorization: DIGEST realm="elinkdashboard.com",nonce="BroadWorksXg7wgu 8teTdg0oyzBW",username="2147052058",uri="sip:208.7 7.200.13:5060;transport=UDP",algorithm=MD5,qop=aut h,cnonce="1593f31c",nc=00000001,response="326d8249 8cc6f620881aa1361ee9f923"
    Content-Length: 212
    v=0
    s=-
    t=0 0
    a=T38FaxVersion:0
    18:08:23 Receive SIP message # (11/04/2010 23:08:23:784 GMT) # UDP # 542 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUS979d9887-4cf9-4faf-9fc3-a14cb874de5b;rport=5060
    CSeq: 877 INVITE
    WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXg7wgu8vvTu0ydjiBW",al gorithm=MD5,realm="elinkdashboard.com"
    Content-Length: 0
    18:08:23 UA --> CM # CloseCall # reason: Authorization # SID: 5459020672938313812
    18:08:23 CM --> UA # OnCloseCall # OID: 172650 # SID: 5459020672938313812
    18:08:23 Try to send SIP message # (11/04/2010 23:08:23:850 GMT) # UDP # 528 bytes # buff size 1 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    CSeq: 877 ACK
    Max-Forwards: 70
    Content-Length: 0
    18:08:23 Try to send SIP message # (11/04/2010 23:08:23:871 GMT) # UDP # 528 bytes # buff size 0 # from: 24.155.238.18:5060 # to: 208.77.200.13:5060
    Via: SIP/2.0/UDP 24.155.238.18:5060;rport;branch=z9hG4bKEPSVBUS26a2 3205-d8b2-4595-87fe-5a518b16b6c3
    CSeq: 878 BYE
    Max-Forwards: 70
    Content-Length: 0
    18:08:23 Receive SIP message # (11/04/2010 23:08:23:929 GMT) # UDP # 414 bytes # buff size 1 # from: 208.77.200.13:5060 # to: 24.155.238.18:5060
    SIP/2.0 200 OK
    Via: SIP/2.0/UDP 24.155.238.18:5060;branch=z9hG4bKEPSVBUS26a23205-d8b2-4595-87fe-5a518b16b6c3;rport=5060
    CSeq: 878 BYE
    Content-Length: 0
    18:26:12 UA --> CM # RequestMedia # For user 100 # SID: 5459025290028471343
    18:26:12 CM --> UA # OnReportError # Error: UserNotFound # SIP error: 0 # OID: 172661 # SID: 5459025290028471343
    18:26:14 Receive SIP message # (11/04/2010 23:26:14:525 GMT) # UDP # 377 bytes # buff size 35 # from: 216.251.144.53:5090 # to: 24.155.238.18:5060
    There is something wrong with authorization parameters(username="2147052058") or your ITSP(208.77.200.13) does not support T.38 codec at all. ITSP replies with "SIP/2.0 401 Unauthorized " on Quadro change media to T.38 every time.
    Try to disable T.38 on the used extension and leave only "Enable Pass Through FAX".
    Regards.
    Default Enable Pass Through FAX
    Thanks for the quick response. I tried this and got the same result. I have a ticket into the ITSP. I will update when I know more.
  1. email me when call quality drops below...?
    By coax_k in forum 'How Do I' Questions
    Last Post: 06-03-2009, 10:57 PM
  2. Call drops out across VPN
    By coralsea in forum Troubleshooting and Problems
    Last Post: 04-28-2009, 02:27 AM
  3. Conference call drops first call after 1 minute
    By abp-support in forum Troubleshooting and Problems
    Last Post: 04-15-2009, 01:19 PM
  4. Call Drops on Unconditional Call Forwarding
    By ASL-Support in forum Troubleshooting and Problems
    Last Post: 03-09-2009, 04:51 AM
  5. x-lite call drops at 32 secs
    By coastvoip in forum Troubleshooting and Problems
    Last Post: 10-15-2006, 11:57 PM
