Thread: No Ringback Tone on Remote phones
    Question No Ringback Tone on Remote phones
    i have 3 remote sites - one phone each - 2 of the sites (haven't heard any different on the 3rd) intermittently when dialed from an outside line or from within the Quadro M32X 5.1.38 -we get no ringback tone and listen eventually get voice mail for that extension - need help
    Clay
    Quadro M32X
    Under your isdn settings .. check the generate progress tone - maybe set it as conditional ...
    If i am right that should provide ring to your IP handsets on the remote wan side unless I am mistaken and david can teach us both the right way ...
    Cool ringback tone
    thanks for the reply Kevin however, I am not using ISDN on this box it is using the WAN interface with SIP trunking and the phones will work; it's just that they don't always. Maybe I need to set up some type of forwarding on the ports???? I don't know. I had this problem a while back when installing it with 2 sets at the same location and finally got that fixed by using different RTP ports. Not sure on this one.
    thanks,
    clay
  1. Busy Tone
    By HL2DFR in forum 'How Do I' Questions
    Last Post: 10-02-2009, 11:14 AM
  2. No ring tone and others
    By Antonio Santos in forum Troubleshooting and Problems
    Last Post: 07-24-2009, 05:35 AM
  3. Fax Tone
    By lambsons in forum 'How Do I' Questions
    Last Post: 07-13-2009, 01:17 PM
  4. Generate progress tone to IP/PBX
    By iVox in forum Troubleshooting and Problems
    Last Post: 04-30-2009, 01:48 AM
  5. FXO dial tone and precedence
    By networthfs in forum 'How Do I' Questions
    Last Post: 12-19-2007, 12:25 PM
