Thread: Problem with ISDN lines (chanel busy)
    Default Problem with ISDN lines (chanel busy)
    Hi everybody,
    I have a problem with a Quadro 4xi.
    3 ISDN lines are connected to the Quadro, so it gives the possibility here in France to have 6 calls in the same time (out or in).
    But after testing, I'm not able to have more than 4 calls out. But that is strange is that customers can have 4 calls out AND 2 calls in, but not 6 calls out !!
    All my ISDN lines are synchronised and worked so nothing is broked.
    Is it a limit in the Quadro 4xi to have max 4 calls out ?
    Thanks !!
    Re: Is it a limit in the Quadro 4xi to have max 4 calls out ?
    How ever many trunks are allocated in your Call Routing is how many that call route can take.
    Ie if you have allocated all 6 time slots for outbound for your outbound rule.. then that is what you will get.
    If you have allocated 2 time slots.. for that call rule that is all you will be able to get out.
    What does your call statistcis show for successful outbound calls ?
    Hi KSComs,
    I have got this message :
    "Temporary Unavailable"
    ISDN : No circuit/channel available
    or
    ISDN : All channels are busy
    or
    "Line Busy"
    ISDN : User busy
    And the customers use only 4 channels !
    Where could I see that ?
    In my call routing table, I put "Any Port User" ISDN, so it should take the first free chanel. Am I wrong ?
  1. Annoying ISDN Problem
    By lunacom in forum Troubleshooting and Problems
    Last Post: 11-19-2009, 03:29 AM
  2. ISDN 0 channels busy
    By woods in forum 'How Do I' Questions
    Last Post: 09-22-2009, 07:26 PM
  3. Problem transfering call (Busy Signal)
    By ccopley in forum Troubleshooting and Problems
    Last Post: 04-24-2009, 04:06 AM
  4. E1 busy tone error
    By afripayments in forum Troubleshooting and Problems
    Last Post: 11-09-2007, 08:54 PM
  5. busy signal
    By ttsrocky in forum Troubleshooting and Problems
    Last Post: 01-23-2007, 07:05 PM
