Thread: call forwarding method
    Default call forwarding method
    I have a question about call forwarding:
    I have an Epygi Quadro 4x and I would like to know if the call forwarding is with the REFER method (RFC 3515) or RE-INVITE?
    Thank you for your responses.
    Both methods are used in call forwarding depend on configuration settings.
    When the call forwarding to other SIP destinations is enabled directly or via a call routing rule with disabled "Use RTP Proxy" service, call forwarding will be done using “REFER” or “MOVE TEMPORARLY” SIP messages.
    When the call forwarding to other SIP destinations is enabled via a call routing rule with enabled "Use RTP Proxy" service, Call forwarding will be done using “Re-INVITE” SIP message.
    Thanks you very much for this answer.
  1. Call Forwarding
    By Telecom Dave in forum Installation
    Last Post: 07-02-2009, 06:29 AM
  2. Call Drops on Unconditional Call Forwarding
    By ASL-Support in forum Troubleshooting and Problems
    Last Post: 03-09-2009, 05:51 AM
  3. Call forwarding :-(
    By paulk in forum Troubleshooting and Problems
    Last Post: 12-11-2008, 10:06 AM
  4. Alternate method of uploading a wav file
    By ediggin in forum 'How Do I' Questions
    Last Post: 05-19-2008, 11:16 AM
  5. Call Forwarding
    By jscobbie in forum 'How Do I' Questions
    Last Post: 12-20-2007, 02:15 AM
