Thread: FXO Disconnect Settings for Switzerland
    Default FXO Disconnect Settings for Switzerland
    Our QuadroFXO (Analog, FW 5.1.13) is unable to detect the disconnect signal. With the default settings for Switzerland (System->System Config Wizard), neither busy tone detection nor disconnect detection works. After we have set the 'Duration' and 'Silence' Parameters in fxocfg.ci to 500 ms, busy tone detection finally works, but disconnect detection still does not.
    The disconnect signal here consists of a repeated sequence of a 425Hz tone played for 200 ms, followed by 200ms silence. However, I cannot see how those disconnect detection parameters can be entered into fxocfg.cgi. Any hints?
    Look at thread where David gives a beautiful and comprehensive description of configuring the FXO settings:
    http://support.epygi.com/forum/showt...ght=disconnect
    Ruben
    jfilus, we have got inquiry from our distributor in Switzerland on this. The problem is - you have two different singnals for disconnectio, while Quadro has just one place to configure the disconnectio/busy tones. As far as I know you have already applied a workaround (configured settings to cover both tones).
    We, from our side, will include this into our to-do list to consider for future development.
  1. FXO Disconnect Settings SA
    By darryl in forum Troubleshooting and Problems
    Last Post: 10-26-2011, 04:02 AM
  2. FXO cfg settings
    By coimsamx in forum Problem Report
    Last Post: 03-29-2011, 01:53 AM
  3. Pennytel SMS settings
    By esscom in forum 'How Do I' Questions
    Last Post: 03-30-2009, 09:27 PM
  4. Call routing settings
    By rwalland in forum 'How Do I' Questions
    Last Post: 10-22-2008, 03:41 AM
  5. codec settings
    By mheller in forum Suggestions and Feedback
    Last Post: 11-26-2007, 06:49 PM
