Thread: remote softphone
    Default remote softphone
    HI
    I have a problem connecting a remote softphone, to a quadro, a local extension est configured with remote extension set
    it works fine when the quadro is router, the remote softphone registers correctly
    but when the quadro is connected via Ethernet to a router, the WAN IP and the gateway adress are local, the remote softhone doesn't register correctly: "registration error 400: bad request"
    what is the reason ? waht is the proper configuration ?
    you must use remote extension settings in the extension settings. When a softphone or an ipphone are connected on the wan side, they are consider as remote extension. And you must use the ip wan of your quadro in the proxy, domain etc... settings
    wbts, if I understand right, your Quadro is set behind a router, and the WAN of the Quadro is connected to the company's LAN, so WAN IP of the Quadro is local... Right?
    So where do you connect the softphone - in the company's LAN, or in the internet?
    If you connect that in the internet, which IP do you set in the softphone settings as registrar IP?
    wbts, if I understand right, your Quadro is set behind a router, and the WAN of the Quadro is connected to te company's LAN, so WAN IP of the Quadro is local... Right?
    This is the right configuration, the softphone registers remotely through internet
    The IP WAN adress set in the softphone is the public IP adress of the router
    for only testing purpose, the firewall is switch off
    the registration request is well recevied by the quadro but sometimes I got tje message error "BAD VALUE", 400
    What does that mean ?
    Do you get that message on the softphone screen? If yes, you need to see if you receive such SIP message (see your softphone SIP logs). You can copy those logs here...
  1. IP Phone and Softphone conflict when traveling
    By IBIS_SOEN in forum General Discussions
    Last Post: 04-02-2009, 07:44 AM
  2. Unable to connect using softphone
    Last Post: 01-15-2009, 04:11 PM
  3. Forward a call when softphone is not registered
    By Epygi-Mystream in forum 'How Do I' Questions
    Last Post: 09-01-2008, 07:29 AM
  4. Get two remote extensions operating at one remote location
    By sjet701 in forum 'How Do I' Questions
    Last Post: 08-26-2008, 10:41 AM
