Thread: No ring tone and others
    Default No ring tone and others
    I there
    I'm having a little annoying problem with one extension.
    I have a Quadro 2xi with Boot loader: 3.0.29/Release Firmware Version: 4.1.40/Release.
    All the phones are Grandstream BT100. In one of the extensions when I make a call through the ISDN I don't ear anything not even the ring tone, but the other end ears me.
    when i make the same call through a sip provider it works fine, i cant find the problem to correct it. Can you guys give some help about this subject.
    The other problem is, sometimes when i'm in the middle of a received call through the isdn i ear very loud beeps and the call disconnects, any idea?
    Best regards
    António Santos.
    Quadro 4.1.40 is early firmware, I would suggest to upgrade it to the latest 5.1.19 firmware to start unless you desperately need 4.1.40 ....
    I would also check the provisioning of the BT100 handset and verify its settings and also is it a remote extension or is it a Lan side extension ? What is different about this telephone compared to the others ?
    The problem isn't on the phone, because if I configure another extension on that phone it works fine. So the problem is with the extension.
    Take a back up of your Quadro, then upgrade the Epygi Quadro firmware, then delete the extension, and re-enable it and try again.
    Does it then do the same ?
  1. Fax Tone
    By lambsons in forum 'How Do I' Questions
    Last Post: 07-13-2009, 12:17 PM
  2. Generate progress tone to IP/PBX
    By iVox in forum Troubleshooting and Problems
    Last Post: 04-30-2009, 12:48 AM
  3. Change ring tone of calling party
    By ccopley in forum 'How Do I' Questions
    Last Post: 04-23-2009, 05:42 PM
  4. No ring tone when calling Aastra monitored extensions
    By harryb in forum Troubleshooting and Problems
    Last Post: 07-24-2008, 02:44 AM
  5. FXO dial tone and precedence
    By networthfs in forum 'How Do I' Questions
    Last Post: 12-19-2007, 11:25 AM
