Hi All,
I am looking for some advice for a problem we are experiencing on our system.
We have quadro 4x4 with a mix of snom 3xx handsets and 2 Aastra 57iCT's.
Quadro is running 5.1.18 firmware
Snoms are running 7.3.4
Aastras are running 2.5.1.41
Since upgrading the system to 5.1.18 we have been having issues with audio on calls between Snom 360 (all other snoms are fine) and Aastra 57iCT.
When a call is made from the Aastra to the snom 360 we get no audio coming from the Snom. Audio from Aastra to snom is fine.
Calls in the opposite direction are fine eg from Snom to Aastra.
The network is a flat subnet with no vlans or NAT.
The problem has been replicated with another separate Aastra handset which is working as a remote extension at another office.
If a call is made from the Aastra to any other extension and then transferred to the Snom 360 the audio is fine. It only seems to be when call is initially terminated onto the Snom 360 that this occurs.
Codecs are all locked to G729a on the Epygi.
I have attached a text file showing SIP trace on the epygi.
Ext 30 is the Aastra
Ext 20 is the Snom 360
The first call is from Ext 30 to Ext 20 (problem audio)
The second call is from Ext 20 to Ext 30 (normal call)
I am at a loss as to where to go from here so any assistance would be appreciated.
Scott
