from version 5.1.18 is problem with function "port forwarding and translating".
For remote access for example:
WANip:76 -> 172.30.0.10:80
WANip:77 -> 172.30.0.11:80
etc.
... is now without function.
Pavel
etc.
Pavel
Pavel, this problem is known to happen on 5.1.17. Are you 100% sure you have it now on 5.1.18 too (this is important to us, as we applied a possible fix to test, and need to know the result)?
If you still have that problem with 5.1.18, please contact Epygi Tech Support, and they will give you an image with a fix.
That sounds familiar...
So is that firmware 5.1.18 or 5.1.17?
You don't need to wait until the problem appear again, Pavel. We are aware of the problem, and so you will get the image as soon as you ask Epygi Tech Support about that.
Hi, David,
I have at this time same problem with other QUADRO16xi version 5.1.31 (our customer) with function "port forwarding and translating".
For remote access we need for example:
WANip:442 -> 172.30.0.1:443 (remote access to QUADRO)
WANip:443 -> 172.30.0.2:443 (remote access to server in LAN)
Next day is first port forwarding without function and remote access to QUADRO is Unavailable.
After restart of Q16xi are both functions in order again.
Please, help me.
Pavel
Hi Pavel
official 5.1 images all have this problem, including 5.1.31. It will be fixed in the new public version, which we are preparing to release now. I suppose the new image with the fix (probably 5.1.36) will be released soon - maybe in a week or two.
If the problem is bad, and you urgently need a solution, please contact Epygi TSS to get it sooner (refer me when contacting them, if needed).
P.S. BTW, do you have port forwardings for VNC or similiar tool on the same 16x?
Hi, David,
Thank you for your important informations. Yes, we have port forwarding and translanting as VNC and tool for equipments on LAN of Q16xi. I got in June (last year) special version of firmware 5.1.18N... from the Technical Support Epygi. Now I make a downgrade from version 5.1.31. The problem with port translation is a security risk, I will be waiting impatiently to version 5.1.36. Thanks again and wish you a nice day.
Pavel
