Hello everyone,
I am using a QuadroIDSN 5.0.26 with a Panasonic NCP500 PBX.
My Panasonic is connected via BRI ports to the Quadro ISDN ports. I am using SIP accounts on the Quadro to make and receive external calls.
I can successfully make calls but I can't receive. When I check the logs with telnet I see the SIP Invite Ack.... but no calls is "forwarded" to my ISDN ports. I have no extensions, i just want all the incoming calls to be forward to the ISDN ports.
In the Panasonic live logs... i see no traces on the BRI port. So i think the calls are "stuck" in the Quadro.
Do I need a special route?
I attached the call routing table.
Thanks for your help.
