Thread: Total operating power requirement
    Default Total operating power requirement
    Hi there,
    I am trying to calculate the total power requirements or an Epygi Quadro but i understand that the claimed 3 watts may not reflect the true power requirement.
    ie
    A 16x will draw more power due to powering the fxs ports with ring etc.. where as a 2x will have less power requirements.
    I need the true ratings.
    Kevin, did you see this thread: http://support.epygi.com/forum/showthread.php?t=982?
    It is somehow close to the topic you are talking about.
    Thank you David, I should have used the search feature a little more rigorously..
    Out of interest could you update this for all of the units and sticky that in the forum or make a whitepaper for it.
    http://www.apc.com/tools/ups_selector/index.cfm
    The above is what I used to gauge what sort of UPS would be needed for around 250watts - 500watts at 30 - 60 minutes up time.
    You're right, Kevin - this info should be updated and placed into some easily visible place.
    Here attached is a detailed updated doc on this.
    In the KnowledgeBase area I also published an article containing brief information on power consumption of Quadro units:
    http://support.epygi.com/index.php?_...cleid=13&nav=0.
    Attached Files Attached Files
  1. Get two remote extensions operating at one remote location
    By sjet701 in forum 'How Do I' Questions
    Last Post: 08-26-2008, 09:41 AM
  2. Voice mail impact from power outage
    By warren in forum Tips and Tricks
    Last Post: 09-26-2006, 11:42 AM
