Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2 phones in the same extension
    I have a problem similar to this one,
    I want to use AA to call 2 extensions at the same time (11 and 19 in this case).
    I figured I add Virtual extension (79 in this case) and I want to run MER on it but I dont know how to attach lines 11 and 19 to extension 79
    Hope someone can help me.
    Banned
    Jul 2006
    Dakabin
    79
    Hey Mate,
    Try this,
    Go to extn79 "user settings".
    Select the "Supplementary Services" tab, "Caller ID Based Services".
    Select "any address"
    Select "Many extn ringing" tab
    Select extns required with a tick (11 and 19)
    Select "enable" from tab.
    Select "enable service" in tick box and select "save" at bottom of the page.
    Hope this helps.
    Cheers
    Mike
    Now I see this I overlooked the "Enable/Disable" button on the top and I just clicked "save" when selected the lines I wanted to attach :O
    Many thanks
  1. Sending AA(Extension 50) to extension 13
    By Dataserver in forum VXML Scripting on Quadro
    Last Post: 10-21-2008, 09:34 AM
  2. phones
    By bsnquadro in forum Hardware Interoperability
    Last Post: 02-26-2008, 02:39 AM
