Thread: Call routing
    Unhappy Call routing
    Hello
    I have one Quadro 2x , but i create new Call routing
    i need to blocked all 06* numbers , i have multiple remote extensions, and one FXO port.
    I create one rule, i have enable, and up , but is possible to call any 06*.., this rule is for FXO port.
    I create one rule for IP-PSTN , but i don´t say in Destination Host
    Thanks for all.
    Can you list all rules you have now in your Call Routing Table?
    If you want to be able to call to any number starting with 0, but which doesn't have 6 as the second digit, you can add a rule like this for FXO:
    pattern="0{?,!6}*" (or "0{0-5,7-9}*", which is the same), call type=FXO".
    thanks
    I need block dial to 06* numbers ,
    I have a 0 Call routing , to call for the FXO port
    Ok, in that case you will need to remove the "0*" rule from call routing and add the "0{?,!6}*" rule instead with exactly trhe same settings: only the pattern should be "0{?,!6}*" instead of "0*".
    To remove the "0*" you will need to pass through "System Configuration Wizard", and select the "PSTN Access Code" = empty. This will delete the "0*" rule. Then you can add the "0{?,!6}*" rule.
    Yes. If different , but clear at this time work perfectly.
  1. call routing ..the best way ?
    By dolmen in forum 'How Do I' Questions
    Last Post: 09-21-2009, 09:37 AM
  2. Call Routing
    By cornepiek in forum 'How Do I' Questions
    Last Post: 10-02-2008, 10:24 AM
  3. call routing
    Last Post: 04-20-2008, 09:25 AM
  4. IVR to call routing table
    By andy.collins in forum VXML Scripting on Quadro
    Last Post: 10-02-2007, 07:24 AM
  5. Prefix Tag on call Routing
    Last Post: 06-27-2007, 10:09 PM
