Results 1 to 10 of 18
Thread: call routing ..the best way ?
    Question call routing ..the best way ?
    I've a question about call routing table.
    Now i've some call routing similar to this :
    5* NDS: 1 IP-PSTN sip.messagenet.it:5061, ML : Yes none
    I would like to make a call routing that permit to some extension to make calls without digit e prefix number ("5") for select their external ip-line.
    I've tried to set this parameters, but don't work!
    Inbound Caller Pattern: 215 (my ext.)
    Inbound ND:
    Inbound Prefix: 5
    Inbound Call Type: PBX
    Does anyone have an example ?
    Many thanks
    Matteo
    Hi Matteo
    you'll need to add a new routing rule for that, which have an inbound filter for your extension. Lets assume your local numbers are starting from "123" and are typically 8 digits long. In that case you need to add the rule like this:
    pattern=123?????, NDS=0, IP-PSTN sip.messagenet.it:5061, ML : Yes none
    the inbound filter on that rule should be
    Talking call routin BEER pattern
    David,
    thanks! now my pattern is complete for my situation.
    "Please tell me your Home/work address" because i must to send you a very "BIG BEER" .
    thank you very much
    Best Regards
    Matteo.
    Wine, please Some good Italian wine Dry white one is preferred
    you dont go cheap do you?
    He knows the Slovenians have good Grappa !!!
    Yep, and Italians have very good wine
    Not necessarily the white one... The red "Lambruscho Dei Gonzaga" from Mantua Hills is also a good alternative
    shouldn't you guys be working rather than organising wine??
    Quote Originally Posted by cornepiek View Post
    ..well, maybe.. But my work is in development... so the forum just is for organizing wine, as you already noticed
    BTW, don't you have any question, Corne?? I just had an idea that it would be nice to try the famous South African "Rubicon" wine...
    There is absolutely nothing selfish in this.., just the wine helps us not to forget our dear customers and their needs .
    Also sometimes a cup of wine helps to understand some of customer requests.., which are difficult to get when being completely sober..
    ok ill bit, here's a questio for you:
    How much wood can a woodchuck chuck, if a woodchuck could chuck wood
  1. Call Routing Table CRT
    By cornepiek in forum Troubleshooting and Problems
    Last Post: 11-14-2008, 05:57 AM
  2. Call routing settings
    By rwalland in forum 'How Do I' Questions
    Last Post: 10-22-2008, 03:41 AM
  3. Call Routing
    By cornepiek in forum 'How Do I' Questions
    Last Post: 10-02-2008, 10:24 AM
  4. call routing
    Last Post: 04-20-2008, 09:25 AM
  5. Prefix Tag on call Routing
    Last Post: 06-27-2007, 10:09 PM
